Question about American Standard 2770.018w.020 Cadet Whirlpool White
I bought American Standard whirlpool tub used. Mod# 2732.018.020. I filled it and pump only buzzes, does not pump. What can I do? Do you have a link to the manual?
  • 125 Answers
No manual. Sounds like the motor is no good. What model and brand of pump do you have?
replacement Bath Pumps
Posted on Feb 24, 2009
My whirlpoop tub not all of the spout work
Posted on Apr 18, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Posted on Jan 14, 2009
Have an American standard whirlpool tub. the on/off button is stuck on on. now the only way to shut the jets off is to flip the breaker to the bathroom. how do I fix this
This sounds like the air switch in the motor is not working properly. You will need to remove the pump from under the tub to access the air switch located in a housing on the motor.
Replacement Air Switch will cost you about $20
US Parts Center
Aug 27, 2013 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Cadet 5' x 36'' Whirlpool white 2771.018W. Bath is filled, turn on, buzz for a few seconds stops and dosen't do any thing. After a few minutes buzz again as if it wants to turn on but nothing.
From the sound of it the pump has seized and the thermal breaker is tripping causing the off and on buzzing sound. The problem could be in the motor or the pump attached to the motor. The easiest way to check this is to pull the pump/motor assembly out and check the rotation of the impeller. The impeller should spin freely with no drag. Most pump/motor assembly have a screw slot in the back under a plug or just open in the middle of the back of the motor. In some cases this test can be done without removing the pump/motor assembly. If the motor and pump do not spin freely, puchase a new pump and motor as one unit..
Sep 06, 2009 | American Standard 2771.002.021 Cadet 5' x...
American Standard Motor humms
I think there is a clear or black tube connected to the pump on the back of the black box on top of the pump motor, there is a nut where the tube attaches to the back, unscrew this nut and pull the tube out. If it is not the tube type switch, the pump motor power plug should be plugged into a black or blue control box, this box should have a wire going to the switch in the tub. If you have a buzzing noise, the pump or motor is probably seized, This is caused from lack of use or using bath oils or soap in the tub, When you get the pump and motor out to check, stick a screwdriver in the back of the motor(center of motor hole may or may not have a plug in it) and turn the screw, itshould spin freely with little or no resistance.
May 08, 2009 | American Standard 2770.018W.021 Cadet 5' x...
Once tub is filled. The whirlpool jets do not work. Do not know if they could be clogged or not. Only hear the sound of the motor.
The impeller in the pump has probably been broken......a costly fix as you can only get a new pump to fix thins.
But just for kicks and giggles......check to see if the intake isn't clogged. Remove the filter/strainer and see if anything is blocking it.
Probably not but it is a free and quick check
Apr 14, 2009 | American Standard Home
Jan 13, 2009 | American Standard 2770.018w.020 Cadet...
American Standard 2770.018w.020 Cadet Whirlpool White Logo
1,205 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
