Question about Lexmark X4270 All-In-One InkJet Printer
Printer won't connect to computer
I have a disc to install my printer, I've used this printer for probably 2 years, or more. I printed a document, then asked it to print another one, and it was stuck in que. I've tried everything to delete this document stuck. I've unplugged everything, left it unplugged for a day or more, when I insect the disc, it tells me after a time of going through other stuff, to plug in the USB and the power to the printer, it's stuck there, it wants me to click on the "sharing with an administrator", I can't continue.
Please help me.
DeeDee Evans
  • Lexmark Master
  • 684 Answers
In Order to delete the Doc stuck in Que............ Go to start click on Run if it is a Vista just type it in Start Search.......... Type Services.Msc and hit enter.......... On that list select Print Spooler right click on it and say stop................ Now click on Start again and type in Spool and hit enter............. Double click on the Printers folder there and select each and everything there land hit delete........ Now that should become empty close that window........... Right click on the Print Spooler and click on Start........... Now go to all Programmes go to Lexmark X***** Series Printer u have and click on Uninstall......... Restart the Computer.......... Download the drivers from the website and install the downloaded drivers it will work................ Thanks
Posted on Jan 15, 2009
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Why isn't it scanning a document to my laptop
I cannot use the scan function on my X5470--specifically, to scan documents into PDF format. "Cannot retrieve Application List" is the messge shown. How do I repair this function?
Make sure the Lexmark OCR scan software is installed on your computer. The software allows you to scan your documents to PDF file. The software is only available on the installation disc that came with your Lexmark printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
The green power light keeps blinking and it won't print, it says it is not getting a connection
Thank you for using fixya.com.
The computer is not detecting your printer. Here's what you need to do:
1. Check all the connections or Reset the connection between your computer and your printer.
2. Press and hold the power button of your printer for 5 seconds to do a power cycle. The printer will turn off.
3. Turn it back on.
4. Print something.
If no go,
1. Uninstall and reinstall the driver of your printer. You can access the driver in Control Panel>Add and Remove Programs. After un installing the driver, put the disc of your printer into your computer's DVD player. Follow the onscreen instructions.
2. Print Something.
If no go, let me know by posting in this thread.
Thank you,
CARLO ADRIAN
FIxya Expert
Jun 04, 2011 | Dell A920 InkJet Printer
I've been using a dell 3100 through a home network for several years. Suddenly I can't print. The network can't find the printer. I can print to it if I connect through USB. I have tried...
Hi
Please check the mention below option
1) First you get any error in your printer screen
2) If you are print through Network please ping your printer if you are not getting the print.
Open command prompt and type ping 192........your pinter ip, if you r getting reply to your printer
its mean your connect to printer.
3) Remove your printer driver and install again.
Jun 01, 2011 | Dell 3100cn Laser Printer
My dell 1815dn when printing also prints random symbols on top of the document. It varies from one line of random symbols at the bottom of the page to about 4-5 lines of random symbols sometimes. I've...
This is most probably a corrupt driver so try the following:
1. Open Printers and Faxes on your computer and delete the driver for your printer. Then go to dell.com and open the drivers and downloads tab. Download and reinstall your printer. If the printer is still printing out symbols, it's most likely either a problem with your connection or with the printer's hardware.
2. Try using a different cable to connect the printer and computer. If you don't have one, connect and install the printer to another computer. If this stops the symbols then you will need to buy a new cable. If it does not then it is most likely a problem with the printer's hardware and you will need to get the printer serviced.
Thank you for using FixYa!
May 25, 2011 | Dell 1815dn All-In-One Laser Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Epson dx8450 printer
Hope this helps. Install the nearest series printer driver it maybe available with Vista (DX8000 series). Other option I used to deal with my client with hard to find drivers, I used printer driver emulation. Hope you still have the manual to check with the printer drivers emulation. Last resort, is to find nearest Epson national distributor or Authorized Service Center. There might however extra fee if needed for the CD copy.
Best regards,
Rosener Guyano
Feb 02, 2008 | Office Equipment & Supplies
Laptop - printer connection
You need to completely remove all drivers pertaining to this printer. Reboot your computer after removing them and then reinstall the latest driver according to the directions for it.
Nov 21, 2006 | HP LaserJet 5L Printer
Lexmark X4270 All-In-One InkJet Printer Logo
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
