Question about Sage Instant Accounts 8.0 (013604ug)
Logging onto Sage problems
Hi
Needed to change a few things in sage corrections and so went into company and corrections, afterwhich I was booted out. Ive been trying to log back in but it says cannot login as (ME) is making error corrections. How do I bypass this??? I think I may have clicked on sort in te corrections field before it kicked me out.
  • julia-clark May 18, 2009
    I have the same problem, and I have deleted queue.dta from as many places as I can find on our computer, and yet I still am being told I am logged in (when I am not), and therefore I cannot go in again. I have rebooted the machine a number of times, definitely each time I have found a new queue.dta to delete, and even left it to think about it's behavour over the weekend (!), and it STILL won't let me in. Is there anything else I can try?
Delete the QUEUE.DTA file from within the ACCDATA folder of your data directory.
Posted on Mar 09, 2009
  • Daksha Nov 29, 2012
    thank you it worked for me - should have done this before instead of restoring the computer
    Thank you it worked - should have done this instead of estoring my computer
Can i use sage instant accounts 12.00 for more than one company on the same computer?
you can, however you would either need to purchase the sage client manager from the store or have to upgrade your license to the sage client 50 which enables multiple companies. i hope this helps
Jan 30, 2012 | Sage Computers & Internet
WE have upgraded a sage program on to new computer. However we cannot restore the backup due to an "unsupported version "error
hi dmatharu667
this happens when you take a backup of a company that has a accdata folder in the accdata folder and it reports version as v9. To correct this go to data directory go into accdata directory and in that director move or delete the second accdata directory, repeat your backup and it should then restore perfectly
Nigel
May 22, 2011 | Sage Instant Accounts 8.0 (013604ug)
I was working in sage instant accounts version 8.2 when my computer crashed. Im trying to go back into sage but it comes up with the message 'you may only run one copy of this programme at any...
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
May 19, 2011 | Sage Instant Accounts 8.0 (013604ug)
I have just upgraded to sage line 50 accounts professional, yet when i try to run it it tells me the data file could not be found.my data is held on another networked computer and i can see that the path...
Hi allweatherra
Sage 50 has a file called company. that holds the path to the sage Data. From version 2007 onwards this is held in c:\documents and settings\all users\application data\sage\accounts\2010(or whatever version you have)
Hope this helps
Feb 10, 2010 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Financial Year in Sage
If you are using sage 50 or Sage instant
the financial year can be changed in settings and financial year and click change button. However this is not available in all levels. It sounds if your backup may be out of date.
May 06, 2009 | Sage Instant Accounts 8.0 (013604ug)
Error message with sage instant accounts
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage 50 Accounts 2008
I think I got the solution for you ...
User Name is Already in Use / Cannot Access YYY because XXX is logged in
Typically, when you get this message you will be asked if you want to remove the user from the request list. If you are asked this question, simply answer Yes and you'll be able to continue.
An alternative solution is to go in the data folder for your sage data (the default folder for versions prior to 14 is c:\program files\sage\accounts\accdata for v14, the folder is c:\documents and settings\all users\application data\sage\accounts\2008\company.000\accdata on XP and c:\programdata\sage\accounts\2008\company.000\accdata. In the data folder, you will find a file called QUEUE.DTA - delete the file and you should be able to get back into Line 50. If you have a multi user version of Line 50, you should only delete this file if you are sure that no-one else is using Line 50.
Mar 20, 2008 | Sage Instant Accounts 8.0 (013604ug)
Restoring Sage back up file
All the back files that was created is on that other machine even while you may think its on that disk in theory YES but physically NO. Thats why you got this: Error message keeps coming up which is: programfiles\sage\accounts\company.001attachments\nominal\1200\statements\288.pdf Just one more try the disk you used look on it if it has the 288.pdf file you may be able to read it from the PDF software and then recreate it in the sage financial creater?
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
3,793 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
