Question about GE JKP85 Electric Double Oven
GE JKP85WOA3WW Microwave when I open the plate turns light turns on but do not heat. Does anybody has any idea how to repair this.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
The microwave door switch broke and we are unable to open it. The inside plate continued to move very slowly around until we located and turned off the fuse. What should we do?
Honestly? Microwaves are not tremendously expensive, and they are dangerous if repaired improperly. You can get a service person to look at it, but I wouldn't unless they offered free estimates. If they can do it inexpensively, go that route. Otherwise replace the microwave. This is not a project for DIY if you have no experience in this area.
Sep 20, 2015 | GE JKP27 Electric Double Oven
MICROWAVE PLATE SPORADICALLY TURNS
Sounds like the little motor that turns the plate is about to die. Just go on line and order a new one and put it in, there not that hard to do.
Oct 14, 2014 | GE Wall Oven Plus Microwave - Model...
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | GE JTP85 Electric Double Oven
GE Je1590 microwave oven turns on nut not heating
heatman101
gf
Mar 01, 2010 | GE JE1590 Electric Single Oven
GE Microwave Model JKP85 Plate does not rotate
Usually this is a bad turntable drive motor in the floor of the microwave but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru ----- www.repairclinic.com
Click here For: GE-Microwave-Parts
Jan 26, 2009 | GE JKP85 Electric Double Oven
Nov 26, 2007 | GE JTP85 Electric Double Oven
Turntable not turning and microwave not working
the switches are on the left or right side or both (there may be two).locate them and theres 2 wires on the switch.jump them out.if there bad replace them as it would be a hazard issue for radiation not to.
Aug 28, 2007 | GE JKP85 Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
GE JKP85 Electric Double Oven Logo
64 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
