Question about Hitachi 43FWX20B 43" Rear Projection Television
Change aspect ratio Hitachi 43FWX20B 43 In. Rear Projection Television
  • 192 Answers
SOURCE: Hitachi Ultravision LCD Rear Projection
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Posted on Jun 24, 2007
video-tek
  • 150 Answers
SOURCE: Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
Posted on Feb 08, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 65 Answers
SOURCE: Aspect Ratio or Input Issue
Not sure but you might be confusing your aspect selection on your DVR with aspect selections on the tv itself. Make sure you use your hitachi remote & check all available aspect ratios. Find one that suits u best
Posted on Apr 09, 2009
Raditronic
  • 196 Answers
SOURCE: aspect ratio problem
enter in the menu and change background to black.
Posted on Apr 24, 2010
Our tv will all of a sudden go black but we will have sound whats wrong? it is a Hitachi model # 43fwx20b
bad high voltage circuit. the audio is on a different power supply circuit so you will still get sound. refer to service tech
Aug 22, 2011 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43fwx20b started with blue lins in screen then one night pic went out still powers up but no sound or pic ,but u can hear a ticking
You need to replace the STK ICs they are big black ICs and will have Part # on them- STK392-110
Mats has ICs $9.95 1-800-628-1118
Jan 06, 2011 | Hitachi 43FWX20B 43" Rear Projection...
Our hitachi 43fwx20b has double vision any ideas?
Yes, set uses two convergence chips, either STK-392-110 OR 120.
Both will need be replaced, I have photos and instructions if you tell me how much skill you have.
Let me know if I can help you, parts cost on EBAY under 20 dollars.
SD TECH
Oct 24, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Tv has a 3d look what can be done to fix it hitachi 43fwx20b
The convergence board is bad. Replace the STK voltage regulators and any associated discolored resistors.
Mar 13, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi Model # 43FDX11B. Will not power
Mine just developed the same problem.. did you find a solution/fix?
Jul 09, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43FWX20B
I have a similar pblm. But your first step is to power on with tv's button. Look into the back through holes and look for 4 green and 1 red LEDs lit. If not there are 3 fuses on the power supply board.Fuses can be easily changed.
next step call service.
Apr 16, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Will not turn on/ black screen
My Hitachi Tv 43fwx20b turn on but not have sound and picture
Jul 03, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
