Question about Grundig YB 400PE AM/FM/SW Radio
Does not run on batteries but runs on AC adapter
When I turn it on the unit's display indicates exhausted cells (yes I've tried fresh batteries :) but on AC-adapter it runs ok.
Previously I've run it on NiMh-cells (1,2V) without problems and now it doesn't even run on higher voltage (1,5V) normal batteries.
Hello. tjl001
you should look the socket ac plug and try to plug in and plug out ,the socket maybe crack or the
spring not work. I hope this can fix you trouble.
Posted on Mar 07, 2009
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Dec 28, 2010 | Computers & Internet
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Everytime i try and turn on my compaqnc8230 the screen stays black but it sounds like its running?
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  7. If still no display, connect an external monitor, check if display is comming.
  8. If Display is coming then your LCD need to replace.
Aug 20, 2010 | HP Compaq nc8230 Notebook
The display is blank/black and while the battery light displays "charged' or on when connected w/power cord, when I disconnect the power cord, it shuts off completely and won't turn back on
SOLUTIONS:
Try to replace with another battery and check if its working or not else do the following
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - AC Adapter works fine
If no - defective AC Adpater
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. If problem persist - the motherboard might be defective.
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Battery indicator light on, but the actuall computer will not come on; What do I do?
Try the following steps:
1. First remove the battery from your LAPTOP and plug in the AC Adapter. Turn ON the Laptop without the battery. Check if it is Working:
If Yes - You need to change your BATTERY
If No - Try checking your AC Adapter
2. The AC Adapter has LED indicator which will light up if it is plug-in to a power source (outlet) Check if it is lighted:
If Yes - AC adapter functions properly
If No - Try replacing your AC Adapter
3. If the problem still persist you might have an a following hardware failure on the following component:
a. RAM - Memory errors - replace with same Memory SPEED or type
b. Motherboard defective - you need to replace your motherboard with a new one.
Please Rate. Thanks. Cheers!
Mar 02, 2010 | Microsoft Compaq Presario C501nr Notebook
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
No response
First follow procedure to try to reset the power.
May 23, 2009 | Acer Computers & Internet
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Grundig YB 400PE AM/FM/SW Radio Logo
231 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
