Question about Refrigerators
Water under crispers in my fridge
I have a whirlpool fridge WRX38RWH6 model fridge. Water is accumulating at the bottom underneath the crispers. I have tried to adjust temp in fridge but makes no difference.
  • jac_h Jan 15, 2009
    ok I actually cannot get the back of the freezer off and you are meaning inside the freezer right? there are no screws. the only screws where to realease the ice tray bracket to hold the ice trays. do I just pull the back off somehow?
    Sniper:
  • 51 Answers
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
Hhi, Yes the drain is plugged. remove the floor panel in the freezer and then the rear panel. Locate the drain hole (right side of drain pan) and melt all the ice. there is an after market drain heater kit that you will need to buy and add to the defrost heater.
It is a design problem. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 25, 2009 | Whirlpool ET1NHMXKT Top Freezer...
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Hi where can I obtain spare parts for a whirlpool fridge model # wrx38rwh6 - I am after a bottom, shelf, vegetable crisper and big milk side shelf. Do you know the price? Thanks Tara
Check phone book for local part distributor or repair facility, most repair shops sell parts. also check links on this site for mail order.
J
Jun 12, 2008 | Whirlpool Refrigerators
Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Apr 10, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
703 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
