Question about Philips 32PFL3505D 32 in LCD TV
Salto una chispa d atras d mi tv philips 32 lcd q puede ser?
dsacco86
  • 1077 Answers
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
ginko
  • 19396 Answers
SOURCE: Philips 32 LCD TV sound no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 5186 Answers
SOURCE: Hi
The supported files are .jpg, .jpeg, .mp3, .alb, .m3u and .pls. Progressive JPEG and JPEG2000 are not supported. MPEG1 Layer 1 and Layer 2 are not supported. The USB drive must be in a FAT (DOS) format. This is from the Annex 3 of the TV's manual.
I hope this helps.
Posted on Apr 21, 2010
SOURCE: Philips 32PF5531D 32 in LCD tv table top stand
I have a Philips 32PF5520D/10 TV and need the Table top stand that fits it - anyone have any ideas where I can get one ?
Posted on Nov 28, 2010
gopakumarg43
  • 74459 Answers
SOURCE: Philips 32PFL3505D 32 in LCD TV How can the TV be
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Posted on Mar 08, 2011
Mi televisor es marca LG y quisiera poderlo apagar y prender con el control del dish network quisiera y me pudieran alludar?
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Aug 24, 2013 | Televison & Video
Como puedo programar el control de la Caja de dish network para que apague mi tv lg
Kimberly.Escobar
DISH L.L.C
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Feb 28, 2011 | DISH Network IR Remote Control
Necesito el codigo para sincronizar mi control de dish network con mi Tv marca ELEMENT. Los numeros de la parte de atras del tv son 3.2
Hola mi nombre es Kimberly Escobar con DISH Network. Con mucho gusto le puedo proveer la informacion que necesita. Ciertos codigos que se pueden integrar al control para que funcione con su television Element serian 627 and 659. el procedimiento a programarlo seria precionar el boton de T.V localisado en la parte de arriva hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 627#. El boton de T.V debera iluminar en rojo 3 veces. Despues de este procedimiento puede intentar usar el control, no le podemos prometer que controle totalmente su T.V. En este link puede encontrar mas codigos y ayuda programando su control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita mas ayuda o tiene mas preguntas pro favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda!
Feb 14, 2011 | DISH Network IR Remote Control
Mi toyota 86 no inyecta gasolina, da chispa pero no inyecta
Pareciera que los inyectores no se estan diparando, ya sea por falta de corriente, o por falta de la orden de la computadora, que sincroniza la abertura momentanea de cada inyector. Haz que alguien intente prender el motor, mientras tu pones el oido cerca de un inyector, o le pones el dedo encima. Deberias sentir una rapida secuencia de clicks. Algo mucho mas complicado es sacar un inyector, sin desconectarlo, y ver si dispara el chorro de gasolina cuando intentas encender el motor.
Jun 21, 2010 | 1986 Toyota Pickup 4WD
Mi carro de repente se memato y ya no quiso en cender al parecer era la bobina, pero el mecanico me dijo que siempre no, que probablemente puede ser un sensor del arbol de elebas...quisiera saber si...
mi carro plymount breezer mod.1996 motor 2.0 de cuatro cilindros de repente se paro y ya no quiso funcionar, no hay chispa hacia las bujias y la bomba de gasolina no funciona.segun me lo checaron y me comentaron que era la bobina y no fue despues que fue la computyadora pero ahorita ya estoy indeciso gracias
Apr 23, 2010 | 1996 Plymouth Breeze
Mi problema es q no tengo chispa pero si tengo pulsos de inyeccion y activacion de bomba de gasolina quisiera saber si es pastilla o bobina o sera la computadora?
Necesito saver que ano es el carro para poderte ayudar pero por lo general a esos carros se le va el modulo de control de la chispa si usa distrbuidor esta adentro pero eso varia de acuerdo con el año asi es que te aconsejo datos mas claros para ayudarte con una mejor repuesta
Jan 09, 2010 | Honda Civic Cars & Trucks
El aire acondicionado de mi trailblazer 03 no funciona en las ventanitas de enfrente solo en las de abajo para los pies...cual puede ser el problema?
El vacío se utiliza para cambiar el flujo de aire a los respiraderos. Suena como usted tienen una manguera de vacío floja o disconnected en el lado trasero de los controles.
Jul 22, 2009 | 2006 Chevrolet Trailblazer Ext
Philips 32PFL3505D 32 in LCD TV Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
