Question about Sony Audio Players & Recorders
DA5OES blinking protector light
The "Protector" light on my Sony DA5OES is blinking and I have no volume
  • 319 Answers
SOURCE: protector message
The only way to reset protect is to eliminate the problem which activated it. Problem may be insufficient line voltage or unit's output circuit. Have unit checked out by prof, tech
Posted on Apr 13, 2008
SOURCE: protector fan
i have the same problem , help me umbertknot@hotmail.it
Posted on Jun 28, 2008
SOURCE: Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Posted on Jan 25, 2009
  • 71 Answers
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Posted on Mar 15, 2009
ginko
  • 19396 Answers
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
How do I stop the blinking lock from blinking
The light uses very little power and would take ages to lower battery voltage . check if a light is on in the boot or glove box .
Jul 18, 2014 | Lexerd - 2011 Toyota Sienna TrueVue...
The red light on the front of the TV blinks all the time. No sound or picture. It is a Sony Model KV-21s65
The TV will cause the STANDBY light to blink or flash when the TV detects an issue.
The number of times the STANDBY light flashes corresponds to a specific issue.
If the TV is plugged into a power strip or a surge protector, please remove it from the power strip or the surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
Also try connecting the TV to different AC wall outlet and check if that helps.
If the issue persists, the TV needs to be Serviced.
The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired.
Please contact the local Authorized Service Center to get the TV serviced.
Nov 22, 2010 | Sony KV-32S65 32" TV
It keeps blinking protetor
The protector circuit protects your amplifier from shorted speakers . One of your speakers , or more speakers are shorted out . To figure it out easily follow these instructions . Turn the unit off . Now unplug all of the speaker wire connections from the back of the unit . Turn the unit on . Make sure the volume is turned all the way down . The protector light should not light up . If it does , the problem is inside the unit itself and we'll have to be repaired at the shop . If the protector light is off than continue on as follows . Connect the speakers one at a time to the unit . Each time you connect a speaker , turn the volume control up and back down making sure the protector light does not come on . When you connect the bad speaker , the protection light should come on . Whichever speaker makes the lights come on when connected is the bad speaker and should be replaced .
Oct 21, 2010 | Sony STR-DA2ES 6.1 Channels Receiver
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
Replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
"PROTECTOR" BLINKING
hi
i also have JVC with same problem. but today i noticed that when i take off the AUX input signal to it .then it works ok for long but when i put AUX input with very high volume then it display PROTECT display.
Sep 08, 2007 | Sony STR-GA7ES
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
