My panosonic washing machine suddenly stop spinning
All the other program are working normally , but its only problem is not spinning .!
  • Washing Mach... Master
  • 17,130 Answers
If there is no power to the motor at the SPIN cycle it can be related to fault in the program cycle in the controller board. Reset and use a different program to confirm this, power off unit for a while and check if the fault clears before you can suspect the controller.
Posted on Dec 11, 2012
  • 1294 Answers
SOURCE: Gorenje WA1541 Washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on Jan 24, 2008
SOURCE: Washing Machine Stopped Working
the wash cycle doesnt work
Posted on Sep 15, 2008
  • 190 Answers
SOURCE: SIEMENS XLM 1600 WON'T GO INTO SPIN CYCLE
Dear customer,
                     When the spin cycle doesnt occur the most recommended steps are
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission.
  You can click on the highlighted words to get details abt the checking procedure..
Plz rate this solution.. thank you..
Posted on Apr 09, 2009
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Error code e71
Blocked filter or faulty pump
Jan 04, 2018 | Zanussi ZWF1440 Front Load Washer
The washing machine is stopping half way through any normal cycle, seems unable to spin then stops. the spin is working on a rinse cycle
Possible that the suspect is the main program controller unit. You will need to check the voltage to the motor during the wash and spin cycle.
If there is no voltage then the controller can be faulty.
Feb 05, 2011 | Zanussi Washing Machines
Washer won't spin water out
it could be the last programe is not finnished and it is stuck on it. i had this problem when the macheane cut out from out of balance and then would not spin, always got code E03 finaly after two day i found the electronics where stuck on the last programe, hence done a wash as normal untill the time was up then it stopped saying end only half way though the new wash so i set to stop and then to spin and it worked again and has worked ok since. i hope this helps someone i could not find any info on a reset button for the system ?????
Jan 01, 2011 | Washing Machines
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Stopped Dead
these machines only have 2 problems
dive coupling no wash or spin
or lid switch machine totallaly dead normally caueded by droping heavily & breaking the housing of the lid switch
Oct 30, 2008 | Washing Machines
Washing machine won't drain water nor spin
You have either a clog in your water pump or it has broke.Most the time it can be fixed by removing the 2 hoses attached and remove all debris.Then make sure it is still working.This will correct the light flashing problem at the same time. Please rate this ~!!!
Sep 09, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
WMA62 aborts all programs after 2 initial spins
if this washer is trying to spin when you put it on a wash cycle at the beginning and it trys a fast spin then you have a timer fault m8 if on the other hand its working fine through the wash cycle and not doing the spin properly then it has to be your belt isnt tight enough if your cab=rbon brushs are fine m8
Dec 09, 2006 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
