Question about Panasonic DMR-ES40V DVD-Video Recorder
Panasonic dmr-es40v u99 error message - Panasonic DMR-ES40V DVD-Video Recorder
SOURCE: Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Posted on Dec 01, 2008
SOURCE: Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Posted on Jan 01, 2009
SOURCE: Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Posted on Mar 13, 2009
SOURCE: Unable to boot up dvr, stops with at error U99
Panasonic has a web site below where you can download drivers to a disc that can be used to update your dvr. It also has
the operationg instructions on PDF that you can download & print.
Hope this is helpful
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-E85HS.O#ts
Posted on May 25, 2009
BLAZZ81
  • 281 Answers
SOURCE: I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Posted on Feb 26, 2010
U99 error problem. how can i fix it?
After that if the machine has settled down, restore factory settings from setup. Use a METICULOUSLY clean approved disc and hope for the best!
Jan 23, 2015 | Panasonic DMR-ES40VS VHS / DVD Recorder...
Panasonic DMR-E80H "u99" error message?
It sounds like the HDD is finished, it could not recover, you could see if a computer repair store can help, they have the tools and the software to take it further, but I would consider cost for the attempt.
Apr 02, 2012 | Panasonic DMR-E80H DVD Recorder
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
