Question about Nordic Track C900 Pro
Just assembled a new c900 plugged it in the letters SE appeared on the screen. We can't turn off the demo mode and can't get the treadmill to start. Any ideas
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a C2155.
http://www.youtube.com/watch?v=E-q-uS4t6so
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet.
Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Watch this videos:
Posted on Nov 09, 2011
ercupa190
  • 12223 Answers
SOURCE: Just assembled a new Nordic
Watch this video and Steps:
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check too: Optical Sensor: if have it.
ercupa190
  • 12223 Answers
SOURCE: I have a 2yr old
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
Posted on Nov 10, 2011
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 23, 2013 | Reebok Exercise & Fitness
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Oct 15, 2013 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
My precore 9.43 starts to run then in 5 seconds turns itself off. Says ERROR- nothing more.
proceed according and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Jan 25, 2013 | Precor 9.4 Treadmill Motherboard Motor...
Nordictrack exp 1000X will only run on pre-programmed
When in Demo Mode, the console will go through a repeating lighting pattern. This mode will only become active when the treadmill is plugged in, the main on/off switch is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be turned off at any time.
1.the STOP button while inserting the safety key tPress and hold o enter the user information mode.
2.Look in the Calories window. When Demo Mode is active, the letter 'd' will appear.
3.Press the SPEED DOWN button to toggle the mode on and off.
4.Once the mode is set as desired, remove the safety key.
Follow the steps and fix it.
God bless you
Jan 18, 2013 | Exercise & Fitness
I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 15, 2012 | Exercise & Fitness
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    I have a 2yr old A2550 which just recently started showing only demo information. The belt would not come on nor would the key change the system to manual mode. I used information mode just to see if...
    information mode.
    appear.
    May 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
    I've got a Pro-Form 680 LT Treadmill. Right out of the box, it has the symptoms of being in Demo Mode. You place the key on the Console and it goes to zero but then every button you push causes three beeps...
    Should be instruction in your manual on how to take it out of demo mode. I believe it is press the stop button and insert the key. Then press the arrow down speed button once and the letter D that was on the display will disappear. You may have other problem like a damaged upright cable.Call the number in your manual for service as you should have a free 1 year warranty.
    Oct 01, 2010 | Proform 680 LT Treadmill
    Nordic Track C900 Pro Logo
    158 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Electro Med Services...
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
