Question about Kitchen Ranges
Where do you light the pilot on model SF302BEGW
Where do you light the pilot for oven
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
That model has an igniter.
Posted on Dec 11, 2012
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: The oven pilot to our
have you done testing and checking the unit, it seems that your problem was on the thermal fuse, and this part need to be replaced if you find it burned or busted
Posted on Aug 07, 2008
jsrock516
  • 5911 Answers
SOURCE: My oven takes a long time for the fire to show up
Longer warm up times and slow ignition is most commonly attributed to an oven igniter that is going bad. As these igniters age, they become weak and require replacement. The following link explains some theory behind how they work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The model number you have listed uses the Carborundum type igniter. The part number is 4342528. Replacements can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary, so shop and compare.
NOTE: If the replacement igniter comes with a connector plug that does not match the one on your range, you will be instructed to cut the old connector plug off and splice the wires together using a set of ceramic wire lugs that are included in the replacement kit. DO NOT attempt to use standard wires lugs. They will melt due to the extreme heat in an oven. The ceramic lugs and the wires on the igniter are heat resistant.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Dec 07, 2009
SOURCE: How do you light the oven pilot light? The model
We are replacing the range . . . too old and no parts are available.
Posted on Dec 29, 2009
  • 439 Answers
SOURCE: Vulcan A1990 Model 60XL;
You need to replace the thermocouple for both sides of the oven. That is the most common issue with pilot lights and gas burners. The safety shut off will engage when it does not sense any heat, ie: thermocouples.
Posted on Sep 08, 2010
How to light pilot light with sealed broiler oven
What make and model is it? I maybe able to help.
Aug 25, 2016 | Kitchen Ranges
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Magic chef oven, can't figure out how to light it
Hi, Remove the floor panel inside the oven. Here are both style oven pilot pictures. First one is the model with a standing pilot light7fb2e1e.gif Here is the model with an electronic ignition
Jul 15, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
