Question about HP Photosmart 3310 Printer
HP3310 Printer error
Trying to print an 8.5 by 11 doc but get an error saying the paper size is not supported. How do I fix this problem?
  • Anonymous Jan 23, 2009
    I have the same printer and just started getting this same error when I am trying to copy things with 8.5x11 paper.  Does anyone have a fix.
  • 495 Answers
Set this paper size in your printer control panel to default.
Posted on Jan 13, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ... Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ... Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ... There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ... > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp5550 error 41.5 every time I try to print double sided.
Make sure the print driver settings say it is printing the right size of your paper. It may have paper blocking a sensor or the sensor is bad.
Nov 04, 2017 | HP LaserJet 5550 Printer
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
I have an error msg saying load plain letter SSF 024-969
I guess that you normally use A4 paper. If this is the case you are most likely printing from a document that was created using the Letter paper size (typically a Word Doc of PDF file created in the USA). The solution is to reformat the document that you are trying to print, to A4. You may change the formatting of the document when doing this and page numbers may be incorrect when compared to the index and contents pages.
Oct 15, 2009 | Dell 2130cn Laser Printer
It doesn't print It says size paper error
This problem occur when ink head is dirty and also the head cleaning plastic mechanical cleaner is full of jammed color. 3210 model can be opened and the ink head plastic cleaner can be changed. The ink head is the moving part on the metal axel.
Isopropanol is good for cleaning.
Oct 06, 2009 | HP Photosmart 3310 Printer
Says no paper - but there is paper - was working fine now all of a sudden - have done all the trouble shooting and resetting.
Solved at last!!!
The problem isn't mechanical... I just realized that the "no paper" error posts when the software is trying to print to a paper size not supported by the printer. Go to Page Setup and make sure Paper Size is set to Letter.
In my case, the document I was trying to pring was set to Paper Size: Custom, probably because it was a scanned document and it didn't default to Size: Letter automatically. Hope this solution helps someone end their frustration...
Jun 26, 2009 | Brother MFC-8860DN Printer
I cannot print to different size paper
you need to go to the printer set up on the desk top, there you can tell the printer what to do
Dec 18, 2008 | Brother MFC-8440 All-In-One Laser Printer
Printer says out of paper when trying to print
Hi plabise -
just for a future ref: here's a quick link to an hp support doc for that specific error as a first stop for fixing things. best of luck! - JW50
Jun 27, 2008 | HP OfficeJet Pro k550 Printer
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
HP Photosmart 3310 Printer Logo
222 people viewed this question
Ben Johnson
