Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
No power to recently installed after market radio
I am pretty sure I have all the wires hooked up properly but I get no power to the radio. I have checked the wired with a amp meter and get no response. How can I get power to these wires??
Thanks
    Problem Solver:
  • 3 Answers
first check if the fuse is blown . If yes replace it. then make sure that your car batteries gives you a minimum of 12 V and 8 amp current to turn on the unit. also the red terminal should be connected to ignition and yellow to battery. black terminal to negative of battery. you will definitely get the result.
Posted on Jan 20, 2009
    Sergeant:
  • 227 Answers
Assuming that you checked the fuse, is there any wires in the area that are not connected and can you check them for power? If not, ground one side of your meter and take a wire and wrap around the other lead (set your meter for dc voltage) splice or wrap a straight pin onto that wire coming off the meter. Turn ignition on and stab wires until you get a voltage reading. The best wire would be the color wire coming from the radio fuse holder. But at this point you need power so which ever wire that gives you power splice it to power input of the radio.
Posted on Jan 18, 2009
What is proper method to do a clean power Install of Galaxy DX959 CB radio in a 1999 Ford Super Duty f-250 truck?
Find an easy place to mount it,where you would want it . connect your power wires to the fuse box in an empty slot and your on your way.
Sep 14, 2014 | Radio Communications
Installing a subwoofer in a honda integra
if you already have a after market radio hook the remote to either the remote/power antenna wire or the acc/key switch wire hook up rca,s run them down same side of car hook amp power wire down other side of care it stops engine noise make sure you do a good ground iy needs to touch bare metal for best performance hope this helps
Mar 03, 2013 | Kenwood Car Audio & Video
My car radio is not switching on.the name of my car radio is a sony xr ca440x
For the most part, all car stereos, including the Sony XPLOD car stereo will have the same basic wiring with the exception of some additions for connecting to after market amplifiers. They all have a wire for the memory which is continuous power and one for main switchable power. There will be one main ground and a speaker ground. The rest of the wires are for the speakers. These are usually paired as the same color except the wire with the black stripe is the speaker ground. The easiest way to hook up a new radio is to get a pigtail harness for the Sony XPLOD from any store that sells radios. This is a direct hook up simplifying installation. The pigtail has the proper connection to simply plug in to the original connector and the other end to the new radio.
Jun 04, 2012 | Sony Car Audio & Video
1997 saturn memory wire
memory wire is not hooked up correctly, u could have the power wire and accessory wire switched
Mar 29, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
My 1990 Honda Accord radio antenna motor functions opposite to what it is suppose to be. When radio is on the antenna down, when the radio is off antenna up. Even with this reverse function I can feed the...
first of all, is your radio factory or aftermarket? If its factory the you probably have a bad ground or a short in the radio power to antenna. If its after market, then the remote antenna wire is hooked up wrong. Check to make sure the antenna wire is hooked up to the antenna. Good luck
Feb 21, 2011 | 1990 Honda Accord
Trying to hook up after market radio inside my 2005 chevrolet impala using a wire harness but it will not come on. I had another radio installed before this one but someone broke in my car and stole it. I...
I'm not a stereo person, I'm a wire chaser. I looked at wiring for your sound system w/o amplifier in database. Did you check radio fuse for voltage, use a test light, hot all the time. The radio also has to have ground, ground wires are usually black. Did the after market radio come with instructions? Some radios have an anti-theft lock out, if that is the problem I can't help you. Your radio manufacturer may have a web site where you can ask questions? Just to add, the12volt.com
has installer info. It's interesting.
Jun 16, 2017 | 2005 Chevrolet Impala
I cant get the after market radio to work. i followed the color diagram perfectly and it just wont turn on. whats going on? there are two sets of wires and some are even missing...? i dont want to pay...
check for proper ground and check to see if you accidently poped a fuse while connecting the wires.Check to see if there are any in line fuses on the radio wiring and see if they're blown.if not, hook the radio up directly to a car battery(with a fuse in line on the power side) and if it doesnt work then its a problem with the radio, if it does, its a problem with the wiring.
Mar 12, 2010 | 1995 Volkswagen Jetta
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Wiring an after market Sony CD Player into a 89 Jeep Cherokee Laredo
there might be a amp in the car , so you need to make sure the blue wire off the sony radio is hook up the the remote wire to the stock amp
Sep 21, 2008 | 1989 Jeep Cherokee
I am installing an after market stereo deck into a 2004 Chevy Cavalier but I am not getting any power. From my research I need to hook the deck up to the vehicles ignition harness but I do not know where...
ok now this is fun i had a good ole time putting my after market raidio in on my 04 with out the $300 harness that the sterio shops wanna charge a arm and a leg to install you need to run your 12v power source to the igniton fuse its farly simple if you need picture diagrams i can deffianatly post some pictures showing you exactly how to wire it up bc trust me i was mad enuff trying to get my stereo in so i wouldnt mind helping some one else out on getting it installed bc its frustrating not knowing how to do it
Jul 19, 2008 | 2004 Chevrolet Cavalier
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
110 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
