Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Door locked while it was open
It appears that the "Clean Oven" button was pushed while the door was open. The door will no close now because the latch has engaged. The oven light stays on and nothing works because the oven door does not close...it hits the engaged latch
  • 1 more comment
  • joycepetraus Jan 13, 2009
    Thanks Jimbo. I actually tried something similar to this last night. I shut the breaker off to the range, but not for a couple of minutes...maybe just for 30 seconds or so. I'll try again tonight and keep my fingers crossed.
  • joycepetraus Jan 16, 2009
    Unfortunatly, the first solution of turning off the breaker did not work. I had the breaker off for well over 30 minutes but the door remains locked while open.
  • joycepetraus Jan 21, 2009
    Thank you so much. This suggestion worked. I left the breaker off for 24 hours, when I turned it back on, I pressed the "stop" button while manually pushing the lock lever and the door became unlocked. Again, thanks for your help.
  • 258 Answers
If there is a switch to turn the light off which the door would normally press, use your finger to press and hold it and the lock should reset itself
good luck
Posted on Jan 16, 2009
  • Peter Conway Jan 16, 2009
    ...sorry forgot to say don't forget cancel the self-clean cycle first
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you tried running the "Clean Oven" feature again but immediately press Cancel/Stop?
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Kenmore Master
  • 19,396 Answers
To reset the appliance you need to start tripping circuit breaker, as already suggested, but for at least 10 or 15 minutes.
This will drain power completely and reset circuits.
If the oven ios also hot you need to wait for the oven to cool down completely.
As you started self cleaning with door opened now the door latch may still stay engaged, after doing the above.
In this case you need to activate manually the door switch, unlocking it by pressing and holding it with your finger while you cancel the cycle, or advance the timer control to the end of cycle.
If that still does not work, a technician must energise the door latch solenoid to unlock it.
Start leaving the oven unplugged for longer.
Posted on Jan 15, 2009
  • 679 Answers
One or both of the hinges could be bad.There is a way you can check this.
First put the door in the broil position and then lift
and remove the oven door.
Then carefully with a pair of pliers grab the hinge
and move it forward towards the range body.
In most ranges the hinge should actually be able to
rest up against the body (or frame) of the range itself.
Do this with both hinges and see if they rest up against
the range. If one of them doesn’t then it will need replaced.
Take care if you do this because there is a
good deal of spring tension in these hinges. Make sure
you use something to grab on to them such as a pair of pliers.
  • rockfixya
    rockfixya Jan 16, 2009
    is the solution works?
  • 837 Answers
You will need to unplug or turn off the breaker for at least 10 minutes
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
The part number for the latch asm. which includes the switch is W10107820
GENE
Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
My kenmore 46745 or 46749 (both models listed on the manual) door is jammed. I accidentally opened the oven door, stopping a cleaning cycle after only 15 seconds, and now the door will not close...the lock...
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Nov 26, 2010 | Kenmore 45781 / 45782 / 45784 / 45789...
Electric Range Model Number: FEF365CGBD> The oven door is open and the lock is engaged. The lock light is flashing. I tried disconnecting power (from the main breaker) for about 10 minutes but that...
. If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
hold in the door button and push broil until the latch makes a 360 degree
then the door lock should stop flashing and the oven will work again .
Hold the lock button for 3-5 seconds..
if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit.
if still the same problem the door assembly is cracked and that needs replacement.you can get required parts
from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 17, 2010 | Kitchen Ranges
Frigidaire oven door is open; lock is engaged so door will not close. When recommended procedure of holding oven light switch in and turning on oven clean for 20 sec is preformed, the lock moves in and...
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Nov 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
