Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Mr Coffee 87TM E205612 quit brewing
My programmable brewer stopped brewing after only two weeks. It makes two cups and stops, alarm sounds and it will not reset or complete brewing.
5 Suggested Answers
SOURCE: MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Posted on Oct 19, 2009
  • 234 Answers
SOURCE: Mr. Coffee won't brew all the coffee in the resevior
I would say you need to change the filter on it.
Posted on Mar 14, 2009
SOURCE: I bought my mr coffee 4 cup maker less than a week
you have an internal wiring problem, take it back and get a new one....siever
Posted on Jan 15, 2010
SOURCE: my mr coffee pot will not stop brewing when I pour
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Posted on Oct 02, 2010
Coffee stopped brewing well, coffee now brews weak. Even with increased coffee grounds. Clean button won't turn off. Even after 2 clean cycles.
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
Jun 19, 2016 | Mr. Coffee BVMC-PSTX91 10 Cup Programmable...
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
My Mr Coffee Coffee Maker, 12-Cup Programmable, Black - SKX23 just stopped working yesterday. There was no overflow or mess to explain why it won't brew anymore. The power light does come on when 'ON' is...
When heating elements fail they do not brew sad to say before driving that far I would call or email the company about it . lots of coffee makers are not repairable since heating elements are spot welded to the water pot .
Nov 12, 2017 | Mr. Coffee 072179228578 12 Cup Coffee...
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
or
Hope this helps.
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Programmable clock
need to know how to program this brewer, so the timer will not go off in the middle of a brewing session
my email is
wetherbeefamily@excite.com
Nov 15, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
348 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
