My NA-F70B2 Panasonic washing machine , the inside tub not spinning ....!
4 Suggested Answers
SOURCE: panasonic washing machine model no
it is due to the magnet attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. i got the same problem too but luckily the i found the magnet nearby the washing machine.
Posted on Jan 17, 2011
SOURCE: washing machine
Please check if the drain solenoid is functioning. This may caused the problem.
chris
Posted on Mar 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
Panasonic model Na-f70b2 error. U12 and stop motor
Try this: it should give answers to the "self-diagnostics".
http://panasonic.ae/en/manuals/NA-F70B2-65B2.pdf
May 05, 2015 | Washing Machines
Panasonic washing machine model no NA-F90B3 having spine problem ,
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Apr 06, 2015 | Washing Machines
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
Loud wheezing noise on spin cycle
you need to unblock the pipe work from the tub to the pump ,,then the pump,, and the pipe from the pump to the drain
Jan 12, 2014 | Panasonic Washing Machines
Panasonic washing machine model no NA F70B2 U12 problem just installed today shows U 12 when the cycle reaches Rinse and does not move on.
Dec 30, 2010 | Washing Machines
Washer makes clicking noise when tub rotates
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995522231.pdf here is apart break down of your unit. if you scroll down to pg 10 you see the inner baket assy, chances are youve snapped parts(14)which screw into (15). perhaps you found a broken screwhead inside the tub after laundry was done? id remove the agitator screw down the shaft and it will be quite apparent
Nov 07, 2008 | Frigidaire FEX831CS Top Load Stacked...
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing machine
something caught in pump or bottom drum hose,check filter also!!
Mar 19, 2008 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
