Question about Electrolux EIFLS55IIW 27" Front-Load Washer with 4.07 cu. ft. Capacity 11 W
ELECTROLUX WASHER DOOR WONT OPEN - Electrolux EIFLS55IIW 27" Front-Load Washer with 4.07 cu. ft. Capacity 11 W
  • Official Brand Answer
  • 4,342 Answers
Hello - From what you have described the washer may possibly have a communication problem with the control board, defective cord/wiring, and faulty door lock assembly. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer and select a normal cycle. If the washer continues with the same issue then I would suggest contacting a professional to accurately diagnose the unit.
Posted on Dec 12, 2012
3 Suggested Answers
  • 13 Answers
SOURCE: ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Posted on Apr 11, 2009
dburns60
  • 410 Answers
SOURCE: my washer door closes but it shows door still open
Replace the door switch.
Posted on Apr 12, 2010
My electrolux eiflw50l washing machine wont start
Hey friend, thanks for your post!
From the information you have provided your Electrolux washer is not starting. This could be a possible issue with your control panel or door latch. If your door is not communicating that it is closed then the washer will not start. Is your washer displaying any information or error codes? If you can provide any additional information I will be able to assist you further. -Matt
Mar 15, 2015 | Electrolux Washing Machines
The timer on my electrolux front load wont go to zero and allow the door to unlock
Good Morning friend, thanks for your inquiry!
Based off the information you have provided your Electrolux frontload washer the door will not open and the timer is stuck. I would recommend performing a reset on your washer and you can do that by unplugging the power cord or flipping the household circuit off for ten minutes. If that does not help to resolve your issue I would suggest consulting with a professional technician for an accurate diagnosis. It could be a potential problem with your control panel or door latch assembly. I hope this information is helpful. -Matt
Oct 21, 2014 | Electrolux Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
My electrolux ewf 1481 front loader wont spin
Open the flap, bottom right of the front panel and check the filter is clear. Most machines will not spin until they have expelled all the water. You may want to check the hose is not block and any connections to the sink if it's not on a standpipe.
Most new machines have quite sensitive out of balance detection so if it an odd load try again but add a few extra items to allow the machine to distribute the load evenly prior to spin. Hope this helps
Jul 07, 2010 | Electrolux Washing Machines
Electrolux EIFLS55IIW 27" Front-Load Washer with 4.07 cu. ft. Capacity 11 W Logo
568 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
