Question about Ovens
Miele h4220b oven light replacement
I am having trouble replacing the oven light
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need to replace my
Try calling maly at (800) 999-1360 to get your part.
Posted on Nov 22, 2010
  • 15 Answers
SOURCE: i have a westing house
Remove the fuze or switch off the oven circuit breaker in the electrical meter box to make sure power is off.
Remove protective glass cover. It usually unscrews. Even tap with a piece of wood. Unscrew the globe. If globe has broken it still needs to be unscrewed.
Posted on Jan 04, 2011
How much are elements to replace in miele oven
replacement elements for the oven are available from e-bay or your local electrical wholesale shop
prices can vary from costly (genuine ) to cheap for after market( made by the same company for genuine but without the name price
Apr 23, 2016 | Miele Ovens
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
Replacement for inner glass
Replace the entire door, do not try to straighten it. If you or the retailer paid someone to deliver it, they are responsible for replacing it. The retailer where you bought the oven should be able to replace the door for you or you can contact Miele's Service and Repair Support at
Jan 14, 2014 | Miele DG163 Electric Single Oven
Miele 310 oven griller works but not the oven. why?
Remember that some parts of a 240 volt stove require two live wires and most of the controls or elements being only 120 volts require just one live wire. Hence the double pole 40 amp breaker must have tripped but does not appear tripped. Just turn it off and back on to reset
Nov 17, 2013 | Miele Ovens
Ive got a miele classic single oven H363-1BP-KAT. the problem is the oven is not heating up, have you any ideas, thanx.
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 21, 2011 | Miele Ovens
How is the glass cover removed to change globe in a miele oven
unplug the oven, grab cover and turn anti clockwise, sometimes the glass welds itself to its holder and will break, may have to replace this aswell.
Apr 07, 2010 | Miele DG 4080 Stainless Steel Electric...
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Miele delux 609 oven - does not work
If there is no heat in fan oven , then it is 99.9% certain that the fan element is faulty..if your oven has a removable rear panel inside, take it off and you will see the element, Replace as req'd.
Plz rate this solution.
Thanks.
Dec 28, 2008 | Miele Ovens
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
