Question about Chevrolet Vehicle Parts & Accessories
How to remove oil pan on a 2005 chevy silverado
Need to remove oil pan
  • Chevrolet Master
  • 753 Answers
If 4wd you will have to remove frt. diff
Posted on Aug 25, 2014
2 Suggested Answers
perkins48
  • 14384 Answers
SOURCE: need to replace oil pan on 2005 hyundai tucson
Wow,it says to remove engine.click on link to see,ouch.http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0996b43f80375580&partName=Oil+Pan&partId=0996b43f80375580
Posted on Nov 12, 2012
Replacing oil pan gasket 1998 chevy silverado 305 cu.in.
REMOVAL PROCEDURE
  1. Remove the oil level indicator tube.
  2. Raise the vehicle.
  3. Remove the engine oil and the engine oil filter.
  4. Remove the oil filter adapter.
  5. Remove the starter.
  6. Remove the flywheel inspection cover.
  7. Remove the engine mount through bolts.
  8. Raise and support the engine.
  1. Remove the oil pan nuts and bolts. Note the location of any studs to assist reassembly.
  2. Remove the engine oil pan and the gasket.
  3. Clean all sealing surfaces. Refer to Oil Pan Clean and Inspect under Engine Unit Repair.
INSTALLATION PROCEDURE
  1. Install the engine oil pan and a NEW gasket. Refer to Oil Pan Installation under Engine Unit Repair.
  2. Lower the engine onto the mounts.
  3. Install the engine mount through-bolts.
  4. Install the starter.
  5. Install the flywheel inspection cover.
  6. Install the engine oil filter and the engine oil.
  7. Install the oil filter adapter.
  8. Install the oil level indicator tube.
May 04, 2015 | 1998 Chevrolet Chevrolet silverado
How to change the oil pan gasket on a chevy silverado 2001 4x4 1500hd
remove or roll front diff. forward. unbolt pan and lower bellhousing to pan bolts and then remove pan.
Jan 31, 2014 | 2001 Chevrolet Silverado 2500HD
How to remove oil pan in 2003 chevy silverado 2500 hd
You most certainly have to remove the motor mount bolts and jack up the engine to remove it. If exhaust passes under the pan you will need to remove it also.
Also unbolt the fan shroud as it has to move with the fan as you jack up the motor to clear the cross member.
Mar 15, 2013 | 2001 Chevrolet Silverado 1500
Where is the oil pressure sensor located on a 2005 chevy silverodo 6.0 V8 1500
The oil pressure sensor is located on the side of the oil pan and actually reads pressure from the oil pump.
Feb 06, 2011 | 2005 Chevrolet Silverado 1500HD
What is involved with replacing the oil pan on 1998 GMC Sierra?
  • Step 1 Raise the truck using the proper equipment. Use a ramp or a jack and jack stands to support the vehicle securely by following all directions for use provided by this equipment's manufacturer.
  • Step 2 Drain all oil from the Silverado by placing an oil drip pan under the vehicle's engine block, directly under the oil drain plug. The drain plug is located on the oil pan, between the vehicle's tires underneath the vehicle. Use a wrench to loosen and remove the plug allowing the oil to drain into the pain below.
  • Step 3 Notice the various items attached to the oil pan or in the way of the oil pan dropping. For the oil pan to drop, remove the negative battery cable, front differential (only for four-wheel drive vehicles) and the under body shield by using a wrench or socket set.
  • Step 4 Remove the oil pan shield by loosening the four bolts holding it in place along the edges of the shield. Then, remove the cross brace, oil filter, the transmission to oil pan bolts and the oil level sensor.
  • Step 5 Follow the removal of those pieces by removing the bolts from the two front wiring harness, the engine wiring harness retainer, engine oil cooler pipe to oil bolts and the transmission oil cooler pipe retainer using a wrench. Located the closeout covers and bolts located on each side of the engine and remove them.
  • Step 6 Disconnect each of the oil pan bolts using a wrench that will allow the oil pan to drop. The oil pan gasket will also fall off and replacement should occur before reinstalling the oil pan.
  • Read more: How to Drop the Oil Pan in a Chevy Silverado | eHow.com http://www.ehow.com/how_4508109_drop-oil-pan-chevy-silverado.html#ixzz0wi82Ul2u
    Aug 15, 2010 | GMC Sierra 1500 Cars & Trucks
    Not sure i am locating the oil drain plug or the auto trans drain plug on my 2006 chevy silverado 1500. i am almost certain it is the oil drain plug but want to make absolute certain before i drain it....
    Transmissions are drained by removing the pan itself. A new filter is to be installed upon draining. That is why there is no drain pan plug. The Chevy Powerglides were the last American made car with a drain plug in the 1965
    Apr 24, 2010 | 2006 Chevrolet Silverado 1500 2WD
    Remove transmission oil pan cover off my 2005 silverado
    To do this you'd have to disconect first the shift changer ,use a flat driver just snapp it off ,and put it aside, remove all the bolts from the transsmision leaving only the corner ones ,get something to pour the fluid after removing 2 bolts from the corner putting down the pan slowly then get the other two and that does it.
    Feb 25, 2010 | 2005 Chevrolet Silverado 1500HD
    2005 chevrolet silverado 2500hd gasoling engine 4wd, how do l change the oil pump?
    hello, on this vehicle the oil pump is mounted behind the front timing cover. you will have to remove the front diff, the oil pan, then the water pump and lastly the front engine timing cover. takes about 12 to 12 hours to replace
    Dec 02, 2009 | 2005 Chevrolet Silverado 2500HD 2WD
    My oil pan is cracked and I want to know if I have to remove the engine to change this.
    If you can see and get to all of the bolts which hold the oil pan to the bottom of the engine and if it appears obvious that the oil pan can be removed without being blocked by anything else, then you don't have to remove the engine. Come to think of it, I don't think that I have ever seen a car where you had to remove the engine in order to remove the oil pan.
    Apr 20, 2009 | 2005 Chevrolet Cobalt
    Vehicle Parts & Accessories Logo
    Top Chevrolet Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Mike
    Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
