Question about Lexmark X75 All-In-One InkJet Printer
I have put new cartridges into the printer cartridges won't move
The cartridges won't move to the left and I can't print
  • 191 Answers
You may check
1) the cartridge locker is set back to original position
2) check the bell that drive the cartridge is on the right position(not loosen) you can see the bell moving when you move the cartridge by hand.still not fixed
3) check the cartridge driver gear works in the right side cover, the motor not driving the bell if you can not see the gear running when power on.(very rare)
Posted on Feb 06, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
Posted on Apr 22, 2008
SOURCE: The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Posted on Jan 13, 2009
  • 628 Answers
SOURCE: put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Posted on Feb 27, 2009
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
Posted on May 02, 2009
birky09
  • 104 Answers
SOURCE: i put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Posted on Nov 29, 2009
Lexmark x2600 won't recognize new print cartridge
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-539-6275!!!!!
Good Luck!!!!!
Apr 02, 2013 | Lexmark X2600 InkJet Printer
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2) Remove the empty FINE Cartridge.
a) Push down the FINE Cartridge.
b) Remove the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Can't put cartridge into printer
If your replacing the fine cartridge follow these steps. Sorry for jumping in but it looks like your in a hurry. If you already solved it, great.
1 Make sure that the printer is on, and then open the Front Cover.
The FINE Cartridge Holder moves to the left.
i_expl.gif Caution
bullet_s.gif Do not hold the FINE Cartridge Holder to stop or move it.
bullet_s.gif Do not touch the metallic parts inside the printer.
i_important.gif Important
2 Remove the empty FINE Cartridge.
(1) Push down the FINE Cartridge.
(2) Remove the FINE Cartridge.
bullet_s.gif Handle FINE Cartridges carefully to avoid staining your clothes or surrounding work area.
bullet_s.gif Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3 Prepare the replacement cartridge.
(1) Unpack a new FINE Cartridge and remove the orange protective tape (A) gently.
*1 To the FINE Cartridge Holder
bullet_s.gif Do not re-attach the protective tape once you have removed it. Discard it according to the local laws and regulations regarding disposal of consumables.
bullet_s.gif Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
bullet_s.gif Be careful not to stain your clothes and hands with ink on the removed protective tape.
4 Install the FINE Cartridge.
(1) Insert a new FINE Cartridge all the way into the appropriate slot.
The Black FINE Cartridge should be installed into the left slot (ug_maintenance37.jpg) and the Color FINE Cartridge should be into the right slot (ug_maintenance38.jpg).
(2) Push up the FINE Cartridge until it clicks into place.
5 Close the Front Cover.
Hope this does it. I'll check on you later. If this fixes you up just rate it a 4 fix ya and I'll know you're ok.
Mar 26, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark X75 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
