Question about Intel REALTEK nc-r150201 Network Adapter
Using multiple networks
In my office we hav a workgroup network. We recently got internet connection. I installed a additional network adapter in my computer for connecting the modem(internet is only for my computer). When both Internet and workgroup network is connected, only the workgroup network is functioning properly, the internet connection is disabled. I allocated manual IP for workgroup network. and automatic ip for the network adapter to which i ve connected the modem. I want to use both the networks simultaneously. Thanks in advance.
    Problem Solver:
  • 9 Answers
If you are using windows 2000 or later start the routing and remote access service (make sure to set it to automatic) and that should solve your problem.
Posted on Mar 19, 2009
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
Can't connect to internet- wired network -2nd computer works fine - OS XP
I have installed intex 8139D RTL lan card drivers are installed.in divice manager it will showing the device is enabled. And it will showing lan is connected. but when i change from workgroup to Domain it will showing an error message. to communicate with domain.How to solve this problem.
Jul 05, 2009 | D-Link DFE-530TXP Network Adapter
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
Feb 24, 2009 | Computers & Internet
INternet connection
install drivers for lan card
open run cmd
ipconfig/all
it will show u ur ip adress
then ping to gateway
Jan 27, 2009 | Dell Ethernet Card Network Adapter
Windows networking issue
all computers must have same workgroup name and diffrent descriptions and names. try to use set up home and small office network in every computer. its located under control panel network connections if u put there all the same workgroup names and diffrent descriptions and comupter names
Jan 21, 2009 | Learn.com Windows XP Networking Tutorial...
No internet on Wireless home network despite ''excellent'' signal
When Windows Wi-Fi utility reports available wi-fi networks, does yours show up? I would imagine so, if you're being prompted for the key, and you entered it. So, you should be connected to the LAN at that point.
Then it is a question of connectivity. Using "My Network Places", see if you can detect the other computers on the Local Area Network. If they don't show up, but all indicators say you are connected, right click on My Computer, then Properties. On the popup box, you will see "computer name", and beneath that, "workgroup". Make sure that computer is in the same workgroup as the rest of the network. If not, the bottom button will allow you to change the name of the workgroup.
If you can see the other computers on your network, but you just can't reach the internet, take a look at whatever firewalls you are running, and make sure that PC isn't being blocked by one of them. An easy way to check is to temporarily turn all of them off, and see if things start working.
Also, if you can access your hub (using the web interface), check there and see if the Dell desktop is showing up as a connected device at the router.
I would almost bet it is a workgroup issue, but if it isn't, let me know. There are several other things we can take a look at.
Cheers
Nick
Nov 16, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter
Actually i did use win zero config.
My workgroup is correct (because I'm getting the shared internet access)
I'm using XP Pro
I've enabled all the necessary services in Admin Tools
So I can connect t the network its just that when i try to browse the network to locate the shared printers i can't
Mar 28, 2008 | NetGear - WG311 - 54Mbps 802.11g/b...
I cannot connect to internet with my wireless usb adapter
you need to get into your routers settings and make sure that DHCP is enabled to automatically assign ip addreses and also go to the properties of your wireless adapter and ensure obtain ip address automatically is checked. Turn off any WEP or WPA security until you have all the connections, make sure that the adapter is on the same wireless channel as your router and that all the pc's are on the same network workgroup eg WORKGROUP or MSHOME. It may be as simple as right clicking on your wireless adapter icon in control panel>network conections and select connect.
Sep 04, 2007 | Computers & Internet
Intel REALTEK nc-r150201 Network Adapter Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
