Question about Sony PlayStation 2 Slimline Console
Problem reading dvd movies
Hi i have a ps2 slimline the problem is whenever i play a dvd movie in it a massage appears on the screen that unable to read disk and some times it plays the movie and it starts to skip scenes however the dvd is new it plays games fine but sometimes starts to skip scenes when there is a short movie during playing a game help me.i bought it from Pakistan and its model no. is scph-70004
    Problem Solver:
  • 10 Answers
First of all cleaning this lens is no problem just take a cue tip dipped in alcahol and cleane the lens but as far as adjusting the lens i would get someone with a little knoledge of these things to do that also watch for overheating the slimlines are bad about this a cooler helps alot i suggest a double fan laptop cooler you could also get a usb powered one and just plug it into the ps2
Posted on Aug 25, 2007
  • 85 Answers
You need to have your lens cleaned and or adjusted. i suggest you not try it because you can actually break it and or make it worse. My company will be more than happy to fix this problem. Thank you, connie
Posted on Jun 18, 2007
SOURCE:
I have a PS2 Slim and it won't read discs. Every time I put a disc in it won't spin it will just go to the screen that says browser and system configuration. Please help me!!
Causes:
1. DVD has lots of scratches
2. Regional Settings
3. Incorrect DVD settings for PS2
4. No/Incorrect Disc
Remedy:
1. Clean your discs well and avoid incurring scratches. Place it in
its box after use.
2. DVDs have encoding. They are encoded by regions. Thus, you cannot
play region 2 DVDs on a US Playstation mainly because the US
Playstation 2 can only read DVD that are encoded in Region 1 or
those DVDs that are encoded for all regions. Again, US PS2 are
region 1 capable. Japanese PS2s are Region 2 Capable.
3. There are a number of settings for the DVD playback of your
PS2. First is the rating of the DVD. If you want to watch a
rated R movie, make sure your PS2 allows viewing of R movies.
You'll be setting this during the first time that you'll be
watching a DVD. It's just the same as real theaters. It is also
protected with password so you need the person who set it up
the first time in order to bypass the rating settings.
4. Put in a DVD first and make sure that it is a Movie. And,
check #2.
Nov 22, 2010 | Sony PlayStation 2 Slimline Console
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 slim cannot read the ps2 cd game after I'm use it to play a movie dvd.. but it still can play dvd at all..assist me please....
Your laser is probably on its way out -- as a laser starts to fail, it will first stop reading PS2 games (but will read some DVD movies OK). It will then stop reading DVD movies and only play CDs. Finally, it will not read anything at all. You can find a new laser, based on your PS2's model number, at the following website:
http://store.richspsxparts.com/ve12s.html
Aug 03, 2010 | Sony PlayStation 2 Slimline Console
My playstation is unable to read dvd movies do i need some kind of cleaner for it and what type?
dOn wOrRy all u hAv to do is
to turn on uR pS2 witthout puttin a DVD oR aNy diSc........
on mEnu screen gOto [options] by pRessing 'triangle' button.........
a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst
.....then insert the DVD movie........tURn off PS2....
press n hold the reset button till the blue light is turned on
......release the button and press it again..............
it wOuld take a little tYm foR uR DVD movie to be loAded........
be patient till the movie plays it self..............
If uR DVd still wont play then you should clean your PS2's lens Watch this video.....!!!
Oct 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 won't play dvds anymore but will play ps2 games just fine. What happened and can it be fixed?
This is one of the most common problem faced by old thick pS2..........but dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Sep 27, 2009 | Sony PlayStation 2 (PS2) Console
PS2 (75001) plays cds and dvds but not games
take the game back to the store you bought it at,and they might trade it in for a new one!
Mar 15, 2009 | Sony PlayStation 2 Slimline Console
Features of PS2 slimline.
GET U R PS2 MODIFY WITH MATRIX IC AND ENJOY EVER DVD
Jan 13, 2009 | Sony PlayStation 2 Slimline Console
Playing of pirated dvd movies in sony play station slim
This may be because DVD movies have a reigion code on the disk and on a pirated disk this code may be removed. When the ps2 fails to find the code, it aborts playing the disk. I believe the regional lockout for games (which i assume you have disabled) is a different system to DVD lockouts.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
PS2 does not read DVD movies
what kind of mod chip brand was installed
Jan 15, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
251 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
