Question about LG WM2688HWM TROMM SteamWasher
LG Tromm WM2077CW washer vibration problem
LG Tromm WM2077CW Washer. Vibrates like crazy during spin cycles. How can this problem be solved?
5 Suggested Answers
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
heatman101
  • 43501 Answers
SOURCE: washer vibrates on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 05, 2010
  • 185 Answers
SOURCE: MY LG TROMM WM2077CW WASHER
you may have stripped teeth on the motor rotor (plastic) to metal drum shaft. this is found behind rear access cover. you will need a #17 socket and breaker bar to remove rotor shaft bolt. if you have a "LE" CODE displayed, you will need a new hall sensor.
Posted on May 16, 2011
  • 489 Answers
SOURCE: I have a Tromm Washer and Dryer. Washer cycle
You may have a problem with the motor sensor. Replace the motor sensor and it should take care of the problem. As for the mold issue, purchase some washing machine cleaner and follow directions. It should take care of most of the smell issue. Good luck
Posted on Jun 21, 2011
I have a Tromm Washer and Dryer. Washer cycle time taking twice as long as time on indicator. Mildew smell still there after I have cleaned filter and run wash cycle. Drum vibrates horribly on spin...
Jun 21, 2011 | LG Washing Machines
MY LG TROMM WM2077CW WASHER DRUM WILL SPIN FOR A BIT THEN IT STARTS STUTTING AND WON'T SPIN. THANKS SCOTT
May 03, 2011 | LG WM2016C
Washer vibrates on spin cycle
heatman101
May 05, 2010 | LG WM-2277HW Front Load Washer
LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Apr 27, 2010 | LG WM2487H Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Moved washer from Cal to Missouri, since I got here it vibrates the whole house when its on the spin cycle, washer is level
I think you have a weak floor. Place a clear glass of water on the floor about 2 feet from the machine and watch it iwhae it vibrates. Also, you didn't say whether you re-installed the shipping bolts when you moved it. If not, you could have a bent drum(spider) shaft.
Jan 08, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
129 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
