Question about Hardware & Accessories
How do I program a living solutions 24-hour timer 2 outlet model No. YLT-10
Model NO. YLT-10 24-hour timer. I need to know how to program it.
3 Suggested Answers
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
  • 5245 Answers
SOURCE: how to program 110123-130 24 hour timer
1) Copy following link to how to set FM1 series 24-hour timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
2) With your timer, move override button to center position.
Each pin located around edge of dial represents 15 minutes.
Move pin outward for ON, and inward for OFF.
Set current time by rotating dial until current time appears on clock face.
http://waterheatertimer.org/pdf/Armstrong-FM1-timer.pdf
3) Include photo in your question so expert can see timer and make possible identification
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 03, 2012
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Need instructions for Living Solutions 24 hour timer model tm-011
1) Closest timer manual I have to match that timer is the Sunbeam:
http://waterheatertimer.org/pdf/Sunbeam-61048-countdown-timer.pdf
2) Add comment and say what part of instructions work, and what is different for possible additional help.
3) Attach photo of TM-011
Dec 24, 2012 | Hardware & Accessories
How to program 110123-130 24 hour timer
Dec 03, 2012 | Hardware & Accessories
I need instructions for my living solutions 24 hour timer model YLT-10
Not sure about your model YLT-10, but the "YLT-9" is
  • Features: F = Power Off, 0 = Power On, (1-9) = On at dusk and Off (1) to (9) hours later, C = ON at dusk and OFF at dawn.
Oct 22, 2012 | Woods Hardware & Accessories
Timer for GE Model YLT-15
Timer is not identified:
More information needed
Add a comment with clear description of timer.
Copy following link to help identify timer, and download possible manual
http://waterheatertimer.org/GE-timers-and-manuals.html
Oct 07, 2012 | Hardware & Accessories
Westek Indoor 1 Outlet Digital Timer TEO2DHB instructions
Question is unclear:
Do you want instruction manual, or want somebody to read the instruction manual and explain it?
1) Open following link for instruction manual:
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
2) For explanation of instructions:
-add a comment and ask specific question saying what part of instruction is confusing. For example 12 hour or 24 hour format is letting you choose 12 hour am-pm format or 24-hour 'military time' format where hours of the day and night are numbered 1 through 24.
-and you can also take advantage of fixya live support, and expert can speak with you over phone while you program timer.
Sep 25, 2011 | Hardware & Accessories
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
1,194 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
