Question about Frigidaire Affinity ATF7000E Front Load Washer
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it will not start again.
  • Official Brand Answer
  • 4,342 Answers
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Posted on Dec 12, 2012
IFIXALL
  • 868 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
catriver
  • 878 Answers
SOURCE: new frigidaire washer (affinity)
Kimberely, The err 47 means that the control board is not sensing the door lock. First try unplugging the machine for 1 minute and see if it comes back to normal. If it doesn't put it into the door lock test, with the door closed, by doing the following: Turn the program knob to drain spin. Press pause cancel to turn off the LEDs. Within 5 seconds, press and hold the option and pause cancel buttons until the LEDs start sequentially chasing, then release the buttons. All the LEDs will sequentially light. Turn the program knob 4 clicks from the start position clockwise, the door lock solenoid will activate. The door should be locked. Turn the knob one more click clockwise and it should unlock. You can toggle back and forth to test it. If the door lock is working and you are still getting this code, then its a control board problem. You should call for factory service. If you have any more questions, you can email me at catriver1@gmail.com Catriver...post back.
Posted on Jan 21, 2007
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
ngfam1
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
Fridgidaire affinity washer Pau lights every time hit start
Did you check to see if the water outlet valves (that connect to the washer) are Good, Turned On and water comes out? Anyway you are not getting water into the machine either from that or you have 2 (Hot and Cold) water inlet valves are bad (very rare for both to fail). The fault code is usually "PU", not PAU!
Jul 26, 2014 | Frigidaire Affinity ATF8000FS
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Pau err
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
660 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
