Question about Fisher and Paykel GWL11 Top Load Washer
Washer will not fill to appropiate levels
Just had a tech come out yesterday to replace the computer board and drain pump. However, when I tried to do laundry the water would not fill to pre-set levels, and does not wash or spin. What would cause this?
  • Anonymous Mar 23, 2014
    model GW512 keeps filling with water by turning the water off at the wall when it is at the correct level it works fine
  • Fisher and P... Master
  • 19,396 Answers
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Posted on Jan 13, 2009
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Pump oil change, how much oil
There should be a drain plug (bolt) at the bottom of the pump to drain the oil. Undo bolt and drain the oil. Replace bolt and fill pump with new oil. Look for a sightglass on the side of the pump. Fill so the oil level is in the centre of sightglass.
Jan 29, 2011 | Northstar Pressure Washer 2800 PSI
Our washer will not complete a cycle, F21 appears,what is our solution?
You did not mention whether the washer actually pumps the water out of the washer when you are getting the F21 code. If the washer pumps the water out okay, then the pump and drain system are okay.
Excessive suds can prevent the pump from evacuating the water properly and will sometimes result in an F21. When the suds dissipate, the washer will then be able to pump out the water. Look for this type of condition if necessary.
If the drain pump runs but the washer will not drain the water, see if the washer will gravity drain. Pull the drain hose out of the stand pipe or sink and place it in a shallow pan at floor level. If the washer will gravity drain okay but will not drain when the drain pump is running then you will likely need to replace the drain pump.
If the washer will not gravity drain, then you still have a clog somewhere in the drain system. If you have not pulled the hose between the tub and the pump, then you could have a clog in this area.
If the washer does drain normally, then you could have a failed pressure switch, air pressure hose problem, wiring failure or a failed control board. I provided some technical information below that will help you test the pressure switch. Unplug the washer and remove the top panel to access the pressure switch and the electronic control board. If the tub is empty, you should measure continuity (near zero ohms) between contacts 21 and 22 on the pressure switch using a volt/ohm meter. The LEVEL 1, LEVEL 2 and OVERFLOW contacts should all measure open (infinite resistance). If the contacts on the pressure switch are okay, you can check the resistance through the wires at the electronic control board. If you get the correct resistance through the circuits measured at the control board then the control board will need to be replaced. If the wiring harness is bad, it will need to be replaced.
Nov 29, 2010 | Kenmore HE2 Plus Front Load Washer
Water drains out the washer the same time it is trying to fill
Hi- First thing to do is check the drain hose into the wall and make sure there is a bend, 180 degree, loop that is higher than the highest water level in the washer. It is possible that the water is siphoning out. If the drain hose is set-up ok then it sounds like the drain pump is being activated on the fill. Hard to say exactly what is causing this it is most likely either a switch in the timer or the pressure switch are activating the pump at the wrong point in the cycle. You should have a Tech out to look at it.
Sep 24, 2010 | Frigidaire FEX831CS Top Load Stacked...
My washer fills then draind right away, so water r...
Check that the drain hose is not below the water level. If it's too low the water has no reason to stay in the machine...If the water is pumping out, you have a technical problem and will probably need a tech...Good luck....Nomess
May 20, 2010 | Washing Machines
On Spin cycle it continues filling up with water and when it starts spinning the water pours out of the top of machine. Also with Power failure or overload it continues to fill up with water and never...
We are talking about a FAV6800A or FAV9800A machine correct?
You will need the Service Manual for reference. Sears Parts Direct for reference.
If so it sounds like you have a stuck Water Valve or a Pressure Switch malfunction that never signals the Control Board of wash tub water level. And or a possible drain pump/drain line clog. I don't think you have a Drain Line issue because you don't report an ND error code for no drain.
Are you up for troubleshooting to DIY the repair?
If you unplug the washer does water continue to flow which requires you to shut the water valve to the washer? If water doesn’t flow I would next step you through how to check that the Pressure Switch is signaling the Control Board to turn off the 120VAC to the water inlet solenoids on proper water level fill.
Before we go any further let’s hear back from you.
I own a FAV6800A and I'm very familiar with troubleshooting and resolving issues with both it and the LCD version the FAV9800A.........Rich
May 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont spin, stops and clothes soaked. did the trouble shooting and still nothing..;..
Here are some reasons why the washer would act up:
Too many clothes in the washer. Sand and sediment in water level tube. Slow drain pipe. Plugged pump. Washer onboard intel will monitor the water level of the tub through the pressure tube on the water level switch and make a determination if the water was pumped out in a set amount of time. If intel does not get a confirmation then the washer will shut down for fear of a flooding condition. To correct this you must open the drain, straighten the hose, unplug the pump, whatever it takes for the pump to empty the water at the pre determined time set for the on board intel board. If all those things are good and still no joy then computer board replacement might be in order.
Dec 25, 2009 | GE WCVH6260FWW
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
76 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
