Question about Nintendo Wii Console
Can you help me
I am able to press a to continue but no connection after that ?
  • soccermom183 Jan 17, 2009
    we insert the game, press the A button, click on the disc on the wii channels, then it tells us there is an error. we have tried everything.
    Problem Solver:
  • 6 Answers
If the message says"dics reading error and some other bs about troubleshooting" than you might try a product licenced from wii its called the offical wii lens cleaner kit its not in the usa yet.. i bought mine from consoleshop.com once there use search for wii lens cleaner kit its 14.99 and with shipping its about 20.00 you will have to wait a bit cuz its shipped from monnaco. plus the instructions are in japaneese..but if you go to youtube and search wii lens cleaner kit look for one describing how to use it...its quite simple to use and befor my smash bros **** woulnd play and a couple other wouldnt either now all is clean and it works perfect.good luck
Posted on Jan 17, 2009
What should i do, please help on my problem, it happens when i turn on the computer, it displays Press DEL to run Setup and Press TAB to view BIOS message,when i press it, it displays "a disk read...
first make sure there on no disks in the drives cd usb floppy
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
May 31, 2011 | Computers & Internet
Continuously the letter 'z' is pressing and beep sound is coming during restart acer aspire one laptop. pls do the needfull
1. Check if the 'Z' key has got stuck within so that its getting pressed continuously. 2. If so, life it up using any appropriate tool and try restarting your machine. 3. connect any external keyboard and try if the same problem continues. 3. If still problem continues then the probability of having a hardware defect is more and I would suggest you to have a service professional to fix it.
I hope this is helpful to you Thanks
May 16, 2011 | Acer NSK8458AN Keyboard
The printer screen shows change parts and on the wlan computers connected to it says that the drum end soon and that panics me a lot as i paid a lot for this damn computer
Did you recently replace the drum and the warning is unexpected?
Why does the message "Drum End Soon" continue to appear on the LCD after I replaced the drum?
Description:
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
You can use this procedure to reset a drum in order to continue to use up the remaining 'life' of the drum; recognizing that you will need to replace the drum when you start having print quality issues.
You may find this site very useful.
Trust this is helpful. Please vote.
Dec 31, 2010 | Brother MFC-9840CDW Laser Printer
Won't connect with my computer...it says keyboard failure...press F2 to run setup, press F1 to load default values and continue. Problem is the keyboard doesn't work
make sure that the keyboard has a secure connection or control panel,administrive tools,computer management,device manager,keyboards you should find something there
hope this helps
Aug 13, 2010 | Computers & Internet
Hi, I'm having problems connecting my LG Prada KF900 phone to email setup from my hotmail account. Please can you advise how this can be fixed? Thanks
this is hhow i set mine up
go to messaging then settings then go to mailbox > email accounts> add account.
enter your email and password>click continue
then its going to ask u for ur user id from ur email provider which is ur email address again, enter email address>press continue
mailbox type
POP3 > press continue
incoming server:
pop3.live.com >press continue
outgoing server:
smtp.live.com>press continue
turn on the SMTP authentication>press continue
then its going to ask for SMTP username which should auto fill your email and password already. >press continue
Enter your account name it should autofill Hotmail but u can put anything i believe. then press continue its going to ask you "Update Inbox Now?" press yes. its going to ask you for WIFI connection. chose ur wifi connection if available. if your like me and have WAP on ur phone. just click done or back and its going to give u an error like network open fail or something. Ignore it. Then itll say account is added and ready for use something similar. Click on the account. and its going to show you the settings, if you scroll down youll find "access points" change that from WIFI to WAP Settings or whatever your internet setting were set under. then activate. There you will also find other settings like if you want it to auto retrieve and what not choose what u like.
Let me know if you get a problem!
goodluck
Jan 01, 2010 | LG Prada KF900 Cell Phone
Garbage collecting has been continuing for days. Tried removing batteries, didn't work. Tried new batteries, didn't work. Help!!
The calculator needs to be reset.
Install the TIConnect software and run it to open the main application window.
  1. Remove one AAA battery.
  2. Press and HOLD down the [DEL] key.
  3. While still holding down the [DEL key, reinsert the AAA battery and press the [ON] key.
At this point, the message Waiting... Please install calculator software. You will have to install the OS. You must be connected to the Internet.
  • Connect the calculator to the computer with the SilverLink cable.
  • Run the TIConnect software, Click the Updates Button
  • In the pop up window that appears, deselect all save device operating system.
  • Click continue and follow instructions.
Hope it helps.
A screen capture to help you.
Nov 09, 2009 | Texas Instruments TI-84 Plus Calculator
Installed a d-link dir-100
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 11, 2009 | D-Link (DIR-130) Router
Computer not recognizing DI-524??
Jan 11, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a psp 1000. i want to connect to the internet. so i go to settings then network settings. i click on that then go to infrastructure mode.i select new connection then scan. then i select humberto...
Ok I ahve had this problem too.You can't just choose easy,you have to actually choose what type of security your router has or you can't connect to it.Be sure to enter your router information.
Sep 21, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
