Question about KitchenAid Refrigerators
Ice Maker Issues with KSRT25CRMS01
Ice remaining in the ice canister delivery chute is clogging the delivery mechanism, freezing, then melting drip by drip into the drip pan
  • 210 Answers
SOURCE: Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Posted on Jun 03, 2008
jonniewalker
  • 1029 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
  • 9 Answers
SOURCE: Ice maker does not make ice.
JOEHUNT TRY THE WATER VALVE ON THE BACK OF THE REFRIG BEHIND PANEL MAKE THE ICE MAKER GO THROU A HARVEST OR JUST WAIT TO HEAR IF IT GOES THOU A HARVEST THEN YOU CAN SEE IF (1) YOUR ICE MAKER IS ACTUALLY WORKING OR YOU NEED A WATER INLET VALVE ITS 1 OF THE 2 MOST LIKELY THE VALVE
Posted on Apr 11, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
  • 1218 Answers
SOURCE: ice maker issue
The ice maker is designed to add water at the end of the harvest cycle. The time frame is normally 7 seconds.
Dump the ice out of the bucket, and turn the ice maker off. Wait one hour.
Then turn the ice maker on and watch the complete cycle.
See if all the water is entering the ice maker cavity and for no longer than 7 seconds. If the timing exceeds 7 seconds, some of the Kenmore ice makers have a time adjustment. Snap off the front cover and adjust if it is that style.
If it exceeds this time frame, it could be either the water valve in the rear refusing to shut off on time, or the ice maker sending incorrect timing to the valve.Uusually the water valve.
As well, the ice maker well could be cracked causing, water to leak out of the bottom.
If you have erratic water pressure to the house or YOU ARE ON WELL WATER,
then this problems can be chronic and difficult if not impossible to totally resolve.
Posted on Nov 01, 2009
My ice in the ice maker seems to be melting together and they are fusing into big ice cubes that cannot dispense/
This tends to happen when ice has sat in the ice bucket for a couple days of non use. The warmer your kitchen the worst this tends to happen. What's usually happening is the ice bucket is sitting on the door where the ice dispenser sends it to your glass. Since the cavity in the door is exposed to the warm air in your kitchen it can work its way to the ice bucket area via the chute in the door and when the moist warm kitchen air reaches the ice cubes in the bucket it turns everything into melting ice cubes which eventually freezes at some point and clogs up the ice bucket with large globs of ice pieces that the ice crusher can't handle. About the only thing to do is remove the ice globs from the bucket and make new ice. This is not all that abnormal, just a pain though. Try putting something in the chute (small Rag?) to see if this stops it. If it does then there's not a whole lot you can do about it but use the ice machine more often so it doesn't all sit there melting together.
Sep 25, 2014 | Samsung RFG237AARS Bottom Freezer French...
Kenmore Elite side by side - Icemaker chute freezes up, no ice
To make sure I am understanding you correctly, are you saying that after a normal fill, water continues to drip into the ice maker and freezes in the fill chute?? If yes, than replace the water valve.
If not then:
does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Kenmore where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Kenmore and inquire about the aforementioned. If this is your case, there is a good chance they will cover it.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker over flows
Not sure on this brand, but on some ice makers, there is an adjustment for the length of time the water the water runs down the chute. See if the ice maker instruction sheet is in the back of the unit - it may show where and how to adjust the time. Another idea would be to partially close the water valve that goes to the ice maker unit, so less water gets into the ice maker. However, over time, this will mean the valve will leak through when the valve is turned off. Good Luck
Feb 20, 2014 | GE Monogram ZDI15C Automatic Icemaker
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
32 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
