Question about Sage Instant Accounts 8.0 (013604ug)
Error message with sage instant accounts
While trying to print off nominal accounts, there was a problem and the sage instant accounts was not closed down properly. When I tryed to re-start it, the following error is on the screen''Username is in use-the programme cannot connect you at this time''
  • 1 more comment
  • justoby Jan 15, 2009
    Sage accounts was open when Windows update required a restart.This it did and when I tried to open my accounts Notice came up saying
    Username in use and unable to open at this time.
    Help Please
    Sage closed down and would not reopen
    Told me 'Username in use and cannot connect you at this time
    Where did I find it to cose it properly?
  • markedi Apr 17, 2009
    A windows update caused the computer to restart. Sage accounts was not shut down correctly. When I try to go back in to sage accounts, an error message says 'username in use- the program cannot connect you at this time'
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
Posted on Apr 17, 2009
  • 4 more comments
  • Annette McGuigan Aug 19, 2010
    i had exactly this problem and could do a thing with this all day. After reading your helpful hint i deleted the Que data file and to my amazement i could use this application immediately. thank you soooo much.
  • teep1947 Aug 22, 2010
    superb worked first time - thank you so much
  • SageWorker May 24, 2011
    Superb worked first time. I have never used an internet site for error help before and this did what it said on the can!
  • jonathon849 Jun 28, 2011
    Brilliant - i had this problem and this fix worked straight away - thanks so much.
  • Ian Bishop Apr 10, 2012
    I have exactly the same problem, but I cannot find a file called ACCDATA or Queue.dta.
    Can anyone tell me where to look. I have even done a Search for the files, but none were located.
    Thanks
    Bish
  • Steve Aug 03, 2012
    Excellent worked well
    New Friend:
Im recieving an error message when trying to quick print a delivery note, how can I resolve this?
Posted on Jun 13, 2013
I was working in sage instant accounts version 8.2 when my computer crashed. Im trying to go back into sage but it comes up with the message 'you may only run one copy of this programme at any...
May 19, 2011 | Sage Instant Accounts 8.0 (013604ug)
Hi. I am having problems installing Sage Instant Accounts.Just before the the installation process is completed, a pop up window appears with the following message: Component Error Returned the...
It sounds like the SBD installer isn't working you need to ensure you have full administrator rights and you can run setupsbd.exe from the program directory
Nov 04, 2010 | Sage Instant Accounts 8.0 (013604ug)
Instant Accounts 8.0 (013604ug): I am using Sage Instant Accounts version 8 and am ...
Hi.
We had same problem. Our solution:
1. Empty both the 'accdata' and the 'criteria' folders.
2. Start Sage.
3. Restore a previous backup.
This worked for us. Hope it helps you.
May 17, 2010 | Sage Instant Accounts 8.0 (013604ug)
When I try to print reports in the Financial window on Sage Line 50 I get an error message C Prog Files x86|AccRep\*TB.SRT contain invalid path. how do I fix?
find the TB.srt file and copy it into location should solve this. You may also have a problem with profit and loss and balance sheet as these are normally held in same location
Feb 09, 2010 | Sage Instant Accounts 8.0 (013604ug)
Sage Instant Accounts error Message Coming up during installation, Internal error 2753 eirregistration.dll
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Feb 01, 2010 | Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Wrong date on sage accounts plus
go to settings and financial year click on change button and change year.
Mar 11, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage line 50 nominal reports.
reinstall ODBC Drivers usually found in your sage data directory
Jan 16, 2008 | Sage Instant Financial Suite v8.0 CD Win...
Restoring Sage back up file
All the back files that was created is on that other machine even while you may think its on that disk in theory YES but physically NO. Thats why you got this: Error message keeps coming up which is: programfiles\sage\accounts\company.001attachments\nominal\1200\statements\288.pdf Just one more try the disk you used look on it if it has the 288.pdf file you may be able to read it from the PDF software and then recreate it in the sage financial creater?
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
10,255 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
