Question about Thermador C302U Electric Double Oven
Thermador c302 door hinges
We have a thermador c302 double wall oven, we ordered replacement hinges but they are not the same as the original, what do we need to modify and how are they installed?
    Problem Solver:
  • 5 Answers
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
No power breaker good no display on control board model c302
if you can set it, regardless of "seeing it" then the display board is bad and will have to be replaced or rebuilt.
Aug 31, 2014 | Thermador C302U Electric Double Oven
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at www.fixyourboard.com. Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
I have a Thermador smw272 oven that the lower oven door will not close all the way and the light stays on. I have replaced the hinges and roller assemblies three times and I still have the same problem. I...
is the door switch bad?when you open the door all the way if it is at a 90 degree angle the hinges are good also i just looked your model number up and it says the hinges are no longer available part 14-38-045-01
Nov 14, 2017 | Thermador SMW272 Electric Double Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
See fig below
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
Hello, I have a SC272T double oven. Both of the oven doors have sprung and sometimes the light inside will come on. I have looked at the use manual and do not see any instructions on how to correct this....
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer. If you can bare with me for a couple or three hours until I arrive home ( I presently am away and only have my iphone as a means to communicate and all my Thermador files on my PC ) I will post the suggested temporary "fix". Regards, Macmarkus :)
Oct 25, 2010 | Thermador SC302T Electric Double Oven
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Thermador SC302T Electric Double Oven
Thermador C302U Electric Double Oven Logo
530 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
