Question about 488V LED 2Way Remote
Hello, I have a Viper 488V - it will unlock my doors but will not start my car anymore? Any ideas?
5 Suggested Answers
djrecklezz
  • 57 Answers
SOURCE: remote start on, can't unlock doors
there's a short in the wiring
Posted on Jan 06, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
logosc75
  • 625 Answers
SOURCE: Hello. My Viper 5701 suddenly
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Posted on Jan 23, 2011
slick42371
  • 42 Answers
SOURCE: Does Viper 5701 VIPER 5701 2-WAY ALARM w/REMOTE
No this alarm does not do that. You can set it up for passive arming where 60 seconds after the last door is closed the alarm will turn itself on.
Posted on Feb 04, 2011
Testimonial: "Thank you"
Door locks unlocks
may be the remote was opened ad the pads inter changed
Mar 21, 2014 | Viper Vehicle Parts & Accessories
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How do program a new 488v led remote for my car?
Open the drivers door, press and release the valet button one time, press and hold the valet button, siren will chirp. While holding the the valet button, press and release the the lock button on the remote. siren should respond with a long chirp. Release valet button, trun off ignition, test remote.
Sep 15, 2010 | 488V LED 2Way Remote
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
488V  LED 2Way Remote Logo
32 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
