Question about SanDisk Sansa e250 MP3 Player
My MP3 player is not working
I dropped my mp3 player about a week ago and the battery became unattached. After that I unscrewed it and hooked the battery back up. I hooked my mp3 player up to the computer, erased all of the files, and then formatted it. However its not turning on; any suggestions?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 15, 2009
My MP3 got wet and won't come on. help
You probably are not going to get this working again... But, there is a small chance that if you put it aside for a week or two it may, just maybe dry internally and work.
Nov 01, 2014 | SanDisk Sansa Clip MP3 Player
I got my Element mp3 player six months ago and it
Save music to computer. Once music is saved format mp3. Reinstall music back. Then, open mp3 and solder headphone jack back. U should have a working mp3 with working headphones.
Sep 22, 2009 | Audio Players & Recorders
My daughter dropped creativ zen mosaic in the fish tank. at first in worked a bit now its completely dead
remove battery, remove any flash-cards, unscrew open it , let it rest in warm, well ventilated place (on top of a cup board or so, do not expose to direct sunlight and don't place it near a heating or other magnetic fields such as stereo speakers or tv-set,
let it restand dry for one day at least, put it together again, put in a fresh battery:
keep your fingers crossed and turn it on!
as the files on the device may have gone, hook it up to a pc, if it is recognized by windows: good sign,
format the player, copy one test.mp3 to it, unplug and hit play!
good luck
Jun 18, 2009 | Audio Players & Recorders
Mp3 player full and can,t reset it.
ohh..i had a friend too who bought a chinese brand touch screen cellphone. .something about he just accidentally dropped it and the thing didint work back again..ever..like **** ..what the ****..just sayin that chinese brands are like not that gOod
May 18, 2009 | Jwin MP3 Player
Motorola, M25, orange-Won't play
Likely not new but worth the try. Had reviewed various other POSTS, and suggestion to take out battery and let sit for a while. Often cures unknown ills. Took out the new battery that did not work, let it sit overnight, put battery in again next morning and it booted up. This was done after, changing three batteries, after taking in/out the SD card (no real reason, but figured why not) and, after a subtle BANG on each of the corners of the unit......
Nov 07, 2008 | Motorola Mobility M25 MP3 Player
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
My Mp3 wont cut on
warranty void but what i suggest it to let the player run dry completely.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
Blank Screen-Archos Jukebox
Frank, have you tried changing the recharchable batteries?
Nov 16, 2007 | Archos Jukebox Studio MP3 Player
MP3 Won'T TurN on PLZ HELP!
When you dropped it, the batter became loose from the contacts inside, therefore it doesnt charge, but lights up when you connect it to the computer. Remove the 4 screws on the back, then take out the battery and then press it in firmly. Charge the device for about 2 hours. Please add to the question for additional assistance. Best of Luck.
Oct 03, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
