Question about Pentax Optics
Focusing pentax binoculars
How to focus
  • 159 Answers
SOURCE: 12x36 only one eyepiece focus
Assuming you have already tried replacing the battery, contact Canon Service Dept.
Posted on Mar 22, 2008
  • 112 Answers
SOURCE: Binoculars Stiff to focus
if they continue to get stiff then eventually the 3 set screws that hold the focus wheel loosen, and you will have no focus capability, its rare with zeiss but sounds like they should be regreased. the problem is to regrease you have to take completely apart as it is internal focus.if i can help any further contact me@ larry@reichinstruments.com
Posted on Dec 22, 2008
  • 73 Answers
SOURCE: How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
Posted on Jul 31, 2009
  • 32 Answers
SOURCE: unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Posted on Nov 02, 2009
LongPockets
  • 1177 Answers
SOURCE: My Tasco 10x50 InFocus Binoculars
This is normal I'm afraid. "InFocus" is a brand name indicating that these are fixed focus. The name implies that they are magically always in focus, but actually means that they CAN'T be focussed. They have a fixed compromise focus setting that is OK but maybe not brilliant from far distance to fairly close, but actually only completely right at some point in between. If you want binoculars to use for much closer viewing than the compromise distance, you need to buy some with a focussing knob.
Posted on Dec 09, 2010
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
10year old pentax 8x24 PCF G very stiff focus
you cold try lubing it with the drip down method, squirt penetrating oil in the focus rack and hold so it flows into rack. They used a thick grease for damping, you may try heating it in an oven up to 130F for 5 minutes (or leave in a hot car) to soften grease and then actuating the focus to get the hardened grease back into the helix.
Dec 07, 2012 | Pentax Optics
The ridged dial on top of the binoculars does not focus anymore. A child was flipping it back and forth rapidly and something 'gave'
Somebody, Please give us suggestions and solutions to this problem... this is the very same problem with my 10x24UCF WR Pentax Binocular. I'm Jun Galvez from Philippines, Email add: mimo_369423@yahoo.com
Jan 27, 2011 | Pentax UCF WR Binocular
Stiff focus wheel
The number one rule is to never use oil on a binocular!!
I suspect that the multistart thread on the focus arm carrier, which is internal, has become gunged up. This is not an easy repair for a beginner. The rubber has to be removed from the body of the binocular before you can even start to take them apart to determine the fault.
Like any bearing or gear system, the part would have to be cleaned with a degreaser, then reassembled with new lubricant.
Jan 04, 2010 | Pentax PCF WP II (8x40) Binocular
I bought these for my husband. In trying them
Difficult to answer specifically without knowing the model. But binoculars are designed to view objects in the distance. They all have a limit as to how close they will focus based on the magnification and design. Objective lenses that are far apart such as on a porro prism binocular will not focus very close. The nature of the design of having the objectives further apart than the eyepieces doesn't allow it. When trying to focus too close the image will appear blurred and double. That is the nature of the design. 9 feet or 3 metres is considered quite close to focus a binocular and is usually for a model designed to do this such as a roof prism where the objective lens and the eye lenses are inline. A specialty binocular such as the Pentax Papilo will close focus to 50 centimeters. It has been designed so that the objective (large lenses) lenses converge.
Take into account when focusing that binoculars are also designed to compensate for differences in each eye. One of the eyepieces either right or left will adjust seperately. For binoculars with a center focus ring. First focus using the center ring with one eye covered. The eye that should be covered is the one that doesn't have the adjusting eyepiece. When the image is clear close the eye you have just used and leave the center focus alone. Focusing on the same spot look through the eyepiece that adjusts and turn the eyepiece ring until the image is clear. Now all you have to do is focus using the center ring only as the binoculars are adjusted for each eye.
Some binoculars do not have a center focus and each eye will adjust seperately.
Jul 29, 2009 | Optics
Diopter out of ajustment
pentax is one of the good guys and has a great serice center. why no send it back and ask for a replacement, if your sure you are focusing properly there should be no problem. larry@reichinstruments.com
Jun 04, 2009 | Pentax DCF SP Binocular
Can not focus
souns like its out of collimation. dont know if its worth repair or not,if you want we can talk further...larry@reichinstruments.com
Dec 10, 2008 | Pentax Optics
Open Questions:
Optics Logo
27 people viewed this question
Top Pentax Optics Experts
Steve
jasbo
jasbo
Are you a Pentax Optic Expert? Answer questions, earn points and help others
