Question about Dell Inkjet 720 Printer
New laptop Vista
Installed my DEll 720 printer but unable to print
    President:
  • 2,692 Answers
I am guessing that the instal disk that you used was not for VISTA? Download and instal the VISTA driver from the DELL websie for you model printer, below:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=photo+720&rpp=12&p=1&subcat=dyd&rf=all&nk=f&sort=K&nf=19019~7~161365&navla=19019~7~161365&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav
Posted on Jan 28, 2009
Just bought a new computer and my Dell 720printer does not work? Thank you
If you bought a new computer it probably has Windows 7 installed and the Dell 720 may not be compatible. You can try downloading the Vista drivers from Dell here. They may work with Windows 7. If not, you'll need to replace the printer with a later, Windows 7 compatible one.
Jan 09, 2011 | Dell Inkjet 720 Printer
I have a dell 1536 laptop that has never been able to communicate with a printer. I thought I just had one that was too old. I am running Vista and just bought a brand new Cannon printer, still no luck....
Is it a USB printer? Does your USB port on your Laptop work when you connect any Flash memory to it? If so make sure you have installed the current drivers for the printer prior to plugging it into the Laptop.
Jan 18, 2010 | Dell Inkjet 720 Printer
My Dell 720 printer won't work withmy dell 1521
All printers are compatible to a degree.
What operating system are you running on your dell 1521 laptop? What drivers are supported on your Dell 720 printer?
If you are running Windows Vista on your laptop and there are only drivers for your printer up until Windows XP and nothing is on Dell's website for your printer in terms of drivers, then you can only try to run Windows Vista in Compatibility Mode.
If this doesn't work, then you'll need to get a new printer.
Aug 19, 2009 | Dell Inkjet 720 Printer
Dell 924 printer won't work on vista OS
First, here is a link to the vista 32 bit drivers. Install these drivers if you have not installed them before.
Second, if you are using Vista 64 bit, Dell does not make a driver for the 64 bit O/S. You can re-install your Vista to 32 bit or buy a printer that is compatible with 64 bit O/S
Aug 06, 2009 | Dell 924 All-in-One InkJet Printer
Dell 720 printer
Delete the printer icon and disconnect the USB cable. Restart the laptop, reconnect the USB cable to see if your laptop recognizes the printer. If so, install the printer driver. If not, probably USB cable or port issue. Hope this helps.
Aug 05, 2009 | Dell Inkjet 720 Printer
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
Dell photo printer 720
NO u just need first to UNISTALL driver then restart pc and install again from device menager not from setup
Oct 12, 2007 | Dell Inkjet 720 Printer
Dell 720 Printer not printing envelopes.
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Jan 09, 2007 | Dell Inkjet 720 Printer
Dell Inkjet 720 Printer Logo
64 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
