Question about Canon PowerShot S500 IXUS 500 Digital Camera
Memory Card Error
The screen displays 'No Image' in the middle and 'Memory Card Error' at the foot. What is the problem? I can't take any photos.
  • bsliker1 Apr 27, 2009
    I am having the exact same problem. I thought I had a bad memory card that was full of photos. I purchased a new card and still get the same message and not able to take pictures. This started happening when the original memory card in the camera had not been removed in a very long time. I was taking pictures and it just stopped and the memory card error message popped up. Frustrating!
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jan 14, 2009
Late display of picture in lcd in d90 camera what is the trouble in camera
This may be due to a slow or faulty memory card. If the card is damaged, etc. the camera may be "hung up" trying to transfer the image from the buffer to the memory card. Only after this process is complete, can it attempt to display the image to you on the screen. After the images are on the card, and you want to display one or more, the whole process begins again with the camera trying to read the data from the card to be displayed on the screen.
Try again with a new / different card. Be sure to FORMAT the card in the D90 (not in a card reader / computer, etc.) prior to taking any photos.
If you still have problems, you may need to send the camera in to Nikon Service for repair.
Apr 16, 2014 | Nikon D90 Digital Camera with 18-105mm...
PHOTOS CANNOT BE DISPLAYED FOR PRINTING
check the supported image size and file extension of the photo. it is possible that you got a larger orientation on the size of your photo.
let me know
Sep 10, 2008 | Kodak EasyShare 12.0-Megapixel Digital...
My cannon rebeleost3i for some files image cannotbe played back message is displayed what can i do to avoid losing precious shots
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 18, 2013 | Cameras
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
Hi, i can only copy some jpeg images to my 8FF3FP digital photo frame and not others, any ideas why???
it only will show jpeg images no other formats show.
Technical information sheet of 8FF3FPB/00 - 8" (20 cm) Digital Photo Frame - Black + 1GB SD Card With the Philips 8FF3FPB/00 digital photo frame, you can show off all of your favourite digital photos in style!
Its 8" 4:3 screen has a resolution of 800 x 600 pixels, so with the 8FF3FPB/00, you don't need to resize your photos. Plus, the 8FF3FPB/00 uses ImagEn technology to ensure your photos always look their best on this clear, bright display.
The Philips digital photo frame is also an ecological choice, because its SmartPower function allows you to save a considerable amount of energy.
General Device Type Digital photo frame Key Features Digital photo viewer, memory card reader Width 24.5 cm Depth 12.1 cm Height 16.7 cm Weight 494 g PC Interfaces USB Features Auto power off, clock, USB host function, alarm, auto power on Localisation Belgium, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Indonesia, Israel, Lithuania, South Africa, Vietnam, Ukraine, Egypt, Hong Kong, Iran, Pakistan, Romania, Thailand, Malaysia, Singapore, Luxembourg, Hungary, India, Bolivia, Uruguay, Honduras, Guatemala, Panama, Algeria, Morocco, Bangladesh, Philippines, Croatia, Kazakhstan, Slovakia, Slovenia, Korea, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Russia, Spain, Sweden, Switzerland, Greece, Turkey Display Display Type LCD 8" - colour Display Form Factor Built-in Image Aspect Ratio 4:3 Image Contrast Ratio 300:1 Image Brightness 250 cd/m2 Display Format 800 x 600 Status Information Card, firmware version, memory Display Features Brightness Memory / Storage Flash Memory Cards Supported CompactFlash Card type I, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, SDHC Memory Card Digital Photo Frame Operating Modes Landscape, portrait Features Variable slide show speeds Still images Supported Still images Formats JPEG
Nov 30, 2008 | Computers & Internet
Downloading pics to memory card
a virus is present in your pc, infecting the memory card. I suggest that whenever your card leaves the camera and used in any computer or lab, always format the card in your camera not in pc cause this will gonna erase all the pictures including the virus. virus in cf cards wont destroy your camera but it will make it operates like crazy. Make it a standard operating procedure to always format card inside the camera.
Photolab will be able to read even a corrupted card.
Nov 09, 2007 | Canon PowerShot A520 Digital Camera
File error
I have seen this problem with generic SD memory cards so it could be a faulty memory stick.  Try to get a replacement.  If you want to try to recover the pictures you have taken, I suggest Zero Assumption Recovery (Google for it). Check to see if it is compatible with your camera before downloading.
Barry
Sep 17, 2007 | Cameras
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon PowerShot S500 IXUS 500 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
