Question about Canon XL2 Mini DV Digital Camcorder
Canon xl2 is pixelated during playback
Tape play fine a other recoreders. is pixelted on viewfinder
arclight1217
  • 208 Answers
SOURCE: Canon xl2 playback
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Posted on Nov 15, 2008
cpt100
  • 154 Answers
SOURCE: canon xl2 will not take the tape it says remove
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Posted on Mar 26, 2009
cpt100
  • 154 Answers
SOURCE: Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
cpt100
  • 154 Answers
SOURCE: Canon XL2 wont record or playback tapes - grey lines.
The video heads may be clogged. Depending on the severity of clogging, if minor, you can clean the heads with the head cleaning tape other option would be manual and direct cleaning by technician. First, open the tape loading area for dust removal by canned air, clean pinch roller with Q-Tip using denatured alchohol and try it. If it did not do the job. Assigne it to a technician for about $99 for a professional cleaning. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
Posted on Mar 27, 2009
davesoucy
  • 148 Answers
SOURCE: when recording picture looks fine in viewfinder.
makes it clean professionnaly. Cleaning tape is not strong enough for real problem, or glued head...
Posted on Sep 24, 2009
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
I got the problem with my canon XL2 since last 3 months ago. The tape cannot unload sometimes. During recording and run out with tape, try to change with the new one but the cassette compartment cannot...
that is could be the cassette in switch or door swith inter mitent contact, or the mode switch for the mechanism position....
or a good clean up of the mechanism...
hope that will help you
regards allan
Sep 02, 2010 | Canon XL2 Mini DV Digital Camcorder
Canon xl2 will not take the tape it says remove tape in viewfinder.camera is dry whats going on here
Mar 15, 2009 | Canon XL2 Mini DV Digital Camcorder
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Canon xl2 playback
Nov 14, 2008 | Canon XL2 Mini DV Digital Camcorder
No picture during playback
Only thing I can think is the tape may be blank. :) GOOD LUCK
Aug 18, 2006 | Canon ZR100 Mini DV Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon XL2 Mini DV Digital Camcorder Logo
35 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
