Question about HP Office Equipment & Supplies
HP Photosmart C7280 All-in-One Machine will print from most of my prog. files, does all scanning and free-standing printing BUT it will not print any file from my SERIF PagePlus X3 It declares that the page size is wrong and when I correct that it will only "print to Fax"- which I do not need anyway. Is there any way of gently disabling Fax as I am not connected for it and persuade it to print from Serif files. W.M.Owen
  • HP Master
  • 19,396 Answers
The wrong size is because the fax prinbter is set as default printer, or because the printer software is not properly installed and set.
To fix the problem unplug printer USB and try uninstalling from Control Panel>>Add remove programs.
Then do re-installing using HP disk, or downloading software from HP website.
Ensure you start software setup with printer USB unplugged, and also that you set your HP as default printer during installation.
The printer setup wizard will tell you when to connect USB cable to printer.
Posted on Jan 13, 2009
    Sergeant:
  • 431 Answers
Try resetting the printer
  • nematics
    nematics Jan 13, 2009
    www.retrevo.com/support/HP-C7280-Multifunction-Printers-manual/id/3837dj879/t/2/
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
HP C7280 duplex scan problem
IN XP
click on start and select control panel.
in control panel on the top left hand click on switch to classic view if is not there dont worry.
Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
IN vista
Click on start
in the start search box type "printers" and click on ok.
Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
May 29, 2009 | HP Photosmart C7280 Laser Printer
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
Should be in the HP print centre software on your computer
Apr 13, 2009 | HP Photosmart C7280 Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
My C7280 HP photosmart will not scan to my computer.  I get the message "no scan options"
I have had a similar problem that appeared soon after an automatic HP software update over the internet. I solved the problem by uninstalling and reinstalling the HP software that came with the CD. I inserted the CD and ran the de-install for only the program that controlled print and scan and then re-installed the software for print and scan. Straight afterwards, the scanning started to work again
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
