Question about Soleus Dehumidifiers
I have a soleus dehumidifier GL-DEH-50-2 50 pint Capacity, that I can not get to work with a drain hose attached. The bucket just keeps filling up. What am I doing wrong??????
  • 30 Answers
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Posted on Aug 31, 2008
  • 37 Answers
SOURCE: 50 pint dehumidifier has drain hose connected but
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Posted on Jan 27, 2010
tbreeze47
  • 3083 Answers
SOURCE: I have a GE 40
Others have had this problem, and are annoyed by it. One fellow in an Amazon Review fixed it, and here is what he said:
This dehumidifier came with the house I bought 6 months ago. It sucks the water out of the air very well. I had to empty the bucket once a day. I finally figured out how to attach a hose (you have to punch through a rubber barrier with the adapter) and haven't had any problems. The unit is very noisy and I can hear it humming from the 2nd floor. When I move it around a few inches, the noise reduces, but it gets loud again after a while. I might wrap the non-functioning sides with foam to help with the noise.
Not sure what rubber barrier he's referring to, but maybe it will make sense to you- hope so.
Good luck, and hope this helps.
Posted on Aug 22, 2010
  • 4736 Answers
SOURCE: I have a Soleus Air
Several things play a role in the problem you're having.
1. The length of the hose. Shouldn't exceed 5 feet.
2. Is the hose sloping downward from the unit with out any kinks or twists. Most dehumidifiers rely
entirely on gravity to drain the water by hose. It will not drain up and over anything.
3. Is/was there a knockout plug on the dehumidifiers hose connection, that was not removed?
4. Is there a clog in the hose? If so, the water will divert to the bucket.
5. The unit's hose connection or interior tubing is clogged. To solve this problem do the following.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Then monitor the hose for water flow.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Posted on Jul 27, 2011
  • 4736 Answers
SOURCE: I want to have my new 50 pint Frigidaire
The reason this occurs are as follows:
1. The hose is to long (should not be more than 5' in length) or does not slope down and run directly to a floor drain.
2. The hose is clogged or the hose connection on the unit and it's internal tubing is clogged.
First turn the unit OFF & unplug it.
The hose is easy to check by disconnecting it and blowing thru it. If the hose checks out, then it's the connector and internal tubing. Because when this happens, water is diverted to the bucket.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose for water flow.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you solve the problem. Please let me know and thanks for choosing FixYa.
Posted on Aug 15, 2011
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
I have an Energy Star 54701. Turned on, 35 % humidity set, hose connected and ready to drain in sump hole, bucket connected. set for 6 hours. No water is draining from hose or into bucket????
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Soleus 30-Pint Dehumidifier
The water doesn't drain through the site to which I attached the hose. Instead it drains through a quarter inch hole (which appears to be a manufaactured hole, not a crack or break)to the right of...
It sounds like the unit should have came with a plug for the hole. You can probably obtain a plug from a home improvement or hardware store or even improvise one yourself. Also, make sure the unit is pitched so that the water actually runs towards the hose.
Jun 26, 2011 | Soleus Dehumidifiers
What setting do you have to have it on for the water to come out of hose only
The water collection bucket may have a hose tap in it. But, in your case the hose drain connection is on the side of the unit. You have to remove the cover of the hose connection, before you can connect the garden hose. Here's where it gets a little tricky, because the Owners Manual says to leave the bucket in place. However, the Troubleshooting Guide says to remove the bucket, if water is not draining thru the hose. Which to me, makes sense, because the unit can't recognize that the hose is connected, if the bucket is still installed, because it has a safety switch.
In case you have misplaced your Owners Manual, here is a link to it, that you can download and print for future reference.
http://www.natlallergy.com/uploads/pdfs/Soleus-Air-30-40-Pint.pdf
Hope this helps you solve the problem.
Mar 23, 2011 | Soleus 30-Pint Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
Jan 27, 2010 | Frigidaire Dehumidifiers
My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Soleus CFM-40 Dehumidifier
Dehumidifiers Logo
777 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
