Question about HP LaserJet 5200 Printer
My HP 5200 printer won't feed 4x6 glossy photo paper from tray to print photo. Why am I having so much trouble with it?
It prints on copy paper just fine.
  • 81 Answers
SOURCE: Printer (hp photosmart d360) does
Hi.
It looks like the settings have been instable. I suggest you to reinstall the printer and the software provided along with..
Regards
Faraz
Posted on Oct 14, 2008
getbharti
  • 33 Answers
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Posted on Nov 28, 2008
  • 37 Answers
SOURCE: one month old c7280 printer
Here are the steps that HP recommends.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00786157&dlc=en&product=3204785
If you make it the Service the product you will want to call HP and get it replaced under warranty.
Hope this helps
Posted on Dec 04, 2008
  • 199 Answers
SOURCE: HP PSC wont feed through glossy photo paper. Paper
hp printer support low gsm photo glossy like 130-170, or only hp photo glossy they have rough back side to run paper properly
Posted on Feb 27, 2009
fdlixboy
  • 79 Answers
SOURCE: Trouble photo printing
hello.. try to unplug the power cord and usb cord and replug again and also chick the inside part of your printer maybe have a paper jump or ashes due to saying of of paper or try to remove the printer driver software how to remove? go to control panel and click the name (ad and remove program )and you can see the currently install files find your printer driver bellow the currently install files and remove it and install again..........thank you hope i can help you.. have a good day
Posted on Jul 06, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
4x6 glossy postcards feed through slipping
Make sure that the paper meets the specifications for use in your printer.
The paper you are trying to use may be to heavy to be moved correctly through the paper path.
Don
Feb 25, 2010 | HP LaserJet 4200 Printer
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Jul 06, 2009 | HP Photosmart C6280 Printer
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
