Question about Samsung SF-5100 Plain Paper Laser Fax
Need assistance to programme fax machine on 'auto'
Can anyone tell me where in the menu, I find the function to programme how the fax machine receives & sends. Have looked in the menu.
Where can i get the manual for laser fax sf 5100
Posted on Jan 22, 2009
Can't receive faxes
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 22, 2010 | Brother Office Equipment & Supplies
NEED DIRECTIONS TO TURN ON FAX RECEIVING MODE
press menu and fax function and choose tel,tel/fax or fax
May 24, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
When the fax machine rings to indicate an incoming fax...
hi
it appears that the fax machine is in manual receive mode!!
you need to put the machine in auto mode or auto answer or auto receive mode with the reception mode or auto answer button next to the LCD display!!
Feb 03, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Auto answer
first print out a help list this will tell you how to set the rings for the fax machine. it can be set up to ring on the six ring. try going into the receive menu and follow the prompts. good luck
Dec 25, 2008 | Brother IntelliFax-2820 Laser Fax
Change Canon Fax JX200 from Auto print off to on
There are several ways in which Auto Print Off can be engaged, creating the situation you are encountering. It is important to remember that this function serves a specific purpose - to allow for documents to go into memory as opposed to going straight to print. This is often intentional, to save ink and reduce the actual usage of the machine; which will preserve ink and lengthen the life of the equipment, thereby reducing overall cost. Additionally, there are reasons this function is engaged without being purposely set by the operator, most usually in order to prevent loss of received faxes during the existence of some type of error condition.
To choose to receive faxes into memory rather than printing, this is most often done by pressing the on/off button quickly. It could be that you are inadvertently activating "Auto Print Off", if the on/off button was held down too long while turning the machine on. In the normal circumstance, to activate, you touch the on/off button to activate the function, and when you choose to deactivate it, press the on/off button again. Note that this touch should be brief, and not long enough to actually turn the machine on or off.
Along the line of conditions that cause Auto Print Off to activate without operator choice, there are several error states that invoke Auto Print Off. Primarily, these relate to: ink low/out, paper low/out, paper jam, or FINE cartridge issues. As any of these conditions could result in loss of a received fax, the machine switches to memory receipt in order to prevent such loss.
I would suggest, first, to make sure that when you turn the machine on, you do not hold the button after it has begun to start up. Then, if Auto Print Off is displayed (as it carries forward from the last ttime the machine was on), check the settings. Press [Menu], scroll with the up/down arrows to <Data Registration>, press [Start/Copy] and you will see <User Settings>. Use the arrows to select <RX Settings>, press [Start/Copy] and you will see <ECM RX>. Scroll again to <Option Settings>, press [Start/Copy]. Then, you will see <Off> if "Automatic Print Off" is activated, meaning the machine will not print (such as when ink is low), but will store the faxes in memory. Use the arrows to select <On> if you want the machine to print regardless of what it perceives the ink level to be. (Select <On> by using the arrows, press [Start/Copy], and then press [Stop] in order to exit the Menu listing.)
Now, if these steps do not resolve your condition, there could be a couple other issues. The FINE cartridge (ink) must be the specified Canon cartridge, and can not be reused. If the cartridge has previously been used, the machine will not recognize the ink level properly (such as when ink is manually refilled). It could also need cleaning, which is handled through the Maintenance menu. It is also important to remember a particular quirk of this machine, in that when changing the cartridge, you must make sure that paper is in the paper tray first. If all else fails, unplug the machine from the power source, wait at least 5 minutes and then plug it back in.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 14, 2008 | Canon FAX-JX200
My fax machine will not print automatically, it says Auto Print off and I cannot see anything in the manual to change this.
To choose to receive faxes into memory rather than printing, this is mst often done by pressing the on/off button quickly. From the descriptions of the actions you take / have taken, it could be that you are inadvertently activating the function. Holding the on/off button down while turning the machine on could very well be activating "Auto Print Off". In the normal circumstance, to activate, you touch the on/orr button to activate the function, and when you choose to deactivate it, press the on/off button again. Note that this touch should ne brief, and not long enough to actually turn the machine on or off.
Along the line of conditions that cause Auto Print Off to activate without operator choice, there are several error states that invoke Auto Print Off. Primarily, these relate to: ink low/out, paper low/out, paper jam, or FINE cartridge issue. As anyof these conditions could result in loss of a received fax, the machine switches to memory receipt in order to prvent such loss.
I would suggest, first, to make sure that when you turn the machine on, you do not hold the button after it has begun to start up. Then, if Auto Print Off is displayed (as it carries forward from the last ttime the machine was on), check the settings. Press [Menu], scroll with the up/down arrows to <Data Registration>, press [Start/Copy] and you will see <User Settings>. Use the arrows to select <RX Settings>, press [Start/Copy] and you will see <ECM RX>. Scroll again to <Option Settings>, press [Start/Copy]. Then, you will see <Off> if "Automatic Print Off" is turned on, meaning the machine will not print when ink is low, but will store the faxes in memory. Use the arrows to select <On> if you want the machine to print regardless of what it perceives the ink level to be. (Select <On> by using the arrows, press [Start/Copy], and then press [Stop] in order to exit the Menu listing.)
Now, if these steps do not resolve your condition, there could be a couple other issues. The FINE cartridge (ink) must be the specific Canon cartridge, and can not be reused. If the cartridge has previously been used, the machine will not recognize the ink level properly (such as when ink is manually refilled). It could also need cleaning, which is handled through the Maintenance menu. It is also important to remember a particular quirk of this machine, in that when changing the cartridge, you must make sure that paper is in the paper tray first. If all else fails, unplug the machine from the power source, wait at least 5 minutes and then plug it back in.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 08, 2008 | Office Equipment & Supplies
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
Samsung SF-5100 Plain Paper Laser Fax Logo
102 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
