Question about Refrigerators
Jen-Air JSD2989 AE, freezer works but the frig doesn't
  • Refrigerators Master
  • 4,654 Answers
Lets make sure that there are no frost build up on the freezer back wall like this=> HERE If there is a problem with frost building on the rear wall of the freezer the most likely reason will be the=> 61005988 Defrost Control Board
Jen-Air JSD2989 AE, freezer works but the frig doe - 12_11_2012_3_40_57_pm.jpg
The defrost control board can be found behind the control panel inside the fresh food compartment just above the top chef. It is listed as part location 13 in this photo here=> JSD2989AEW Control Components
The next possibility will be the auto damper listed as part location 8 and that part number is=> 61005989 Auto Damper
Instructions on testing and removal of the auto damper and other repairs can be found here=> JSD2989AEW Service Manual
The other two possibilities are the=> 61006199 Defrost HeaJen-Air JSD2989 AE, freezer works but the frig doe - 12_11_2012_4_02_50_pm.jpgt
I will be here should you have questions, Thanks Sea Breeze
Posted on Dec 11, 2012
aborcass
  • 2651 Answers
SOURCE: water in floor
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 26, 2008
peyton32034
  • 410 Answers
SOURCE: Jen-Air Refrigerator does not cool ---freezer works
you have a defrost problem, most common problem component for the jen air refrigerators is the defrost control board pt#61005988. until you change the board you will need to defrost your refrig  manually about once a week. the board is located in the control housing in the refrig compartment and is fairly easy to replace yourself.
Posted on Jan 22, 2009
SOURCE: WHIRLPOOL side by side freezer works fine but frig warm
You may think the freezer is fine, but stick a thermometer in to be sure. It should be around 0 degrees F. If not, you may have iced up coils. See some other posts on this site about getting to those coils and defrosting.
Posted on Jan 23, 2009
  • 15 Answers
SOURCE: Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Posted on Dec 15, 2009
heatman101
  • 43501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
Jen air jcd2289aew freezer working but almost no cold air blowing into fridge
You should not be hearing any popping noise from the refrigerator. That could indicate a defective start relay or attached wiring. Can you tell me the freezer temperature? After the refrigerator has run for a while I need you to remove the rear panel in the back of the freezer. Unplug first and quickly remove the panel and tell me what the frost pattern looks like. Reason I ask is I need to make sure that there is no Freon loss. If there is loss of Freon the evaporator will look like this in photo HERE This problem could also be a defective auto damper in fresh food compartment not allowing cold air from the freezer side. Here is a link to a Service Manual HERE Try these things and let me know what you find. I am here to help you get this refrigerator going, Thanks Sea Breeze
Mar 11, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
GARF19XXYK00, doesn't cool properly, 36 - 40 deg. F on coldest setting. A & E just replaced the bi-metal , defrost part, thinking the defrost keeps it too warm, but guess what, still the sam
There is a TSB on this (TSB) = Technical Service bulletin. You need a service company to order part number W10599551 and put it on. This will fix the problem.
Feb 01, 2013 | Whirlpool GARF19XXYK 19.0 cu. ft....
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
I lost my motherboard (intel dg41wv)'s drivers cd from where can i download the drivers for free
Try here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41WV
If the link doesn't work, go to the intel site, www.intel.com and click on Support >> Drivers and downloads and search for your board.
May 06, 2011 | Intel Essential DG41WV Desktop Motherboard...
THE UP PART OF OUR JENAIRE (REFRIGERATOR) LOSES TEMPERATURE, BUT IT DOES NOT EFFECT FREEZER. iT IS A JEN IRE. iT HAS HAPPENED THREE TIMES NOW AND WE HAVE DEFROSTED IT THREE TIMES.
I have found on some of these units that the light switch by the crisper drawers when being use breaks the door light switch and keeps the light on in the frig side, and with the door closed and no hands on the door!!! use a butter knife to go between the gasket and the housing of the frig door gap the gasket to see if you can see the light on in the frig when the door is shut. If so replacement of the light switch is required.
Dec 24, 2010 | Jenn-Air JB36SEF Refrigerator
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Jan 22, 2009 | Refrigerators
Water in floor
Mar 26, 2008 | Refrigerators
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
