Question about Motorola Talkabout T6210 (14 Channels) 2-Way Radio
Scratchy Transmission One of my radio s transmits a scratchy voice the other is fine. What could cause this issue?
  • Motorola Master
  • 1,654 Answers
The first thing which comes to mind is a bad battery pack. You might try switching the batteries between the two units and see if the problem moves to the other unit.
Secondly, if you only have two radios, it could be the opposite radio has poor receive. You could have a damaged or defective speaker in the receiving unit.
Third, check the speaker grill and mic holes on both units to see they are clear of debris.
If all these items check out, you may need to eventually replace the defective radio. However, to determine which one is defective by trying them with a known good radio.
Posted on Jan 13, 2009
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
I I have an old Uniden PC 55 CB radio that I picked up at a junk store. After some tinkering, it seems to receive just fine (a little scratchy) but it won't transmit. A friend replaced the connector on the...
The final amplifier circuit goes out on these often. It controls transmit power. They transmit, they light up, they emit about .25 watts or less. IMHO, you are done. They simply are not worth anything and there are no parts available for that repair.
May 28, 2017 | Uniden Radio Communications
Aiwa subwoofer TS-WM6 has unclean scratchy sound but pot is OK.. Sound is like when a radio station is not tuned in. Faulty capacitor??
Maybe it's the amplifier board itself causing damage, it might need to be repaired by a professional or the manufacturer that owns the product. If not, you can try to troubleshoot the unit to see what's wrong.
May 12, 2017 | Aiwa TSWM6 Subwoofer
When I transmit on my RCI-995DX people on the other end say that my transmition is scratchy and crackley. I made sure that I as on frequency. Any suggestions? The radio is less than a year old.
Hi, my name is John. Welcome to FixYa. Turn your MICGAIN down a little, or if you have a modulating mic, turn it down. Thanks for choosing FixYa...John
Nov 24, 2010 | Ranger RCI-2995DX Base Scanner
Magnum s980 stopped giving me sound from speaker.also transmit scratchy.audio scratchy.
Pour gasoline inside of it and set it on fire for 5 minutes. When done crank up every thing that can be adjusted inside for more modulation and power. Cheap radio. CB junk.
Sep 12, 2010 | Magnum S9 Base CB Radio
Scratchy dials onGeneral Electric AM Fm tabletop radio
both switches need a good ceaning. go to radio shack get some contact cleaner. Make sure the radio is off take off the back spray contact cleaner into the switch while turning them back and forth. wait till dry.
Sep 14, 2009 | Audio Players & Recorders
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Motorola Talkabout T6210 (14 Channels) 2-Way Radio Logo
139 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
