Question about Kitchen Appliances - Others
My Sunbeam GR 8400 Sandwich Toaster does not work, the lights come on but it does not get hot
2 Suggested Answers
SOURCE: I have a Sunbeam T-40-1 toaster. It doesn't pop
There is an adjustment knob on the bottom turn 180 degrees counter clock wise and try again if still doesn't, drop repeat till successful.
Posted on Aug 30, 2011
Sunbeam toaster 3806 won't stay down and of course won't heat bread.
I have done this a couple of times over the years. Often, it is caused by an accumulation of crumbs around the thermal shut off sensor. This causes the toaster to shut off quicker because it gets too hot.
The fix it is unplugging the toaster, taking the outer shell off and cleaning all visible residue out of the toaster. Compressed air, wooden skewers, and slightly damp, lint free cloths are helpful.
Reminder: if wiping with damp cloths, please let toaster thoroughly dry before reassembly.
This was from another site but is the same as I would say or instead of the sensor, when you push down the handle, you are making a magnet circuit by putting the last part of transformer frame into place - a jammed piece of old toast can prevent this and then your toaster won't work. Unplug it, take it to the garbage can or the sink and pull our the crumb trays and after that, within reason give her a good shake and see what you dislodge
Eric
Good Thi
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
Sunbeam toaster oven
I need an owner's manual for the Sunbeam 6067 Toaster Oven.
Sep 08, 2012 | Sunbeam Toaster Ovens
Sunbeam toaster model 6253 After placing two slices of bread and pushing down the leaver, leaver does not stay locked. What can I do to fix.
This is a maechanical fault and all you need to do is look for a lock that clicks to hold the tray down .This latch is controlled by the bimetal which when hot moves off and releases the tray.
So this strip could have moved off or damaged with use.
Might have to replace or try to repair to keep it in the lock postion..
Sep 20, 2010 | Sunbeam 3822 2-Slice Toaster
AUTOMATIC LOWERING SENSOR DOESN'T WORK
I found another site that described the fix. On the bottom of the toaster, after removing the crumb tray, there is a screw in the middle that can be turned to adjust the sensitivity of the lift mechanism. Here's a link to the site http://www.automaticbeyondbelief.org/fixing.htm
Mar 05, 2010 | Sunbeam 3806 Classic Chrome 2-Slice...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
