Question about Epson Stylus Pro 9600 InkJet Printer
Missing pins on an epson 9600 ink cartridge sensor
Pins appear to be missing
  • 3 Answers
SOURCE: Epson CS3200 - Non-specific power-up failure & error message
Did what you said downloaded the Epson Utility...reset my counters......turned the PRINTER OF and then ON while holding down the Red stop button and the Green colour button at the same time...hey presto......printer works good as new...
Its criminal that Epson makes your printer fail based on the number of copies you do even tho there is no fault with the printer in the first case !!
Do you know if there is a Utility for the Epsom sx400 that i have been foced to buy due to my Red Light fault with the CX3200...cant see it on the download..??
Posted on Jan 18, 2009
SOURCE: epson r340 ink cartridges not recognized
god pm my printer ako na epson r230 ang problem niya ay walang lumalabas na output paano irepair yong
Posted on Feb 13, 2009
  • 11 Answers
SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
Posted on Jul 07, 2009
epsinopin
  • 9 Answers
SOURCE: epson 9600 print head missing numerous nozzels
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Posted on Sep 25, 2009
CaptainHawk1
  • 345 Answers
SOURCE: epson rx595 cannot recognize ink cartridge
Just had this happen to me. Turned it off, turned it back on... nothing. In/out with the cartridge several times and when I blew on the contacts of the printer (where the little microchio on the cartridge touches) it finally worked. Did the blowing on the contacts help? Maybe, but more likely is that the it was just repeatedly trying to d oit before the machine figured it out.
Posted on Sep 26, 2009
Why is it missing fuse pins in relay section of fuse box?
It's normal to see pins missing. They deleted the relay for O2's just ran them on a fuse. And if you don't have a rear blower, you wouldn't need that relay. They also started putting the blower relays in the resistor.
Mar 26, 2016 | 2004 Dodge Dakota
Trying to connect the case to the soyo s7vba133u mother board.
4 pins to the bottom left should be the speaker, top 2 on the right should be the power switch, bottem row shuold hdd led, 2 to left should be reset switch, power led should be top row from left miss 2 pins.
Look at the pins as you pictured them. remember to try the wires in the same pins the other way around, you could have plarity wrong.
Feb 09, 2010 | Soyo SY-7VBA133U Motherboard
Washer Tub appears top be off center after move upstairs. How do I remove cover to check? kenmore washer model # 100.24812200
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 08, 2009 | Kenmore Washing Machines
Canon Rebel Xti won't read ANY memory card. ''There is a problem with the CF card. Please replace the CF card.'' So i went out and bought a new one, the same message still appears! The prongs inside the...
It can be very difficult to see if the pins are bent, and harder to see if any have broken off. Do not probe with anything that can bend the pins. I suggest you create a small tool from a strip of paper and a toothpick. Pass the strip of paper over the pins while watching with a strong light. See if you can count each pin this way. A broken or missing pin will require repair by a Canon authorized facility. Your work will save you a diagnostic fee.
Oct 07, 2009 | Cameras
Bluish green screen on dell laptop
It might be that your red pin is bent out of shape. Please make sure ALL pins on BOTH ends are straight, and none are broken or missing. Also, make sure that they are firmly secure.
Jul 03, 2009 | Dell E176FP 17" LCD Monitor
1 pin bent resulting in "Card Error" message. Attempt to straighten pin broke it off! Camera now appears to work well. What other problems might this missing pin create? Should I keep the camera or replace...
Some of the CF card pins don't do anything. It could be one of those that broke. If, when it was bent, it shorted one of the other pins, that may have caused the "Card Error". Removing the pin may have no negative effect.
Jun 07, 2009 | Olympus EVOLT E-500 Digital Camera
Processor pins missing
Many CPU fit the same socket number. It depends upon how the CPU is wired internally on which pins it uses.
Mar 18, 2009 | EliteGroup P4VMM2 Motherboard
Electric on motherboard
Yes. usually. Most boards have pins missing. The board layout is for all boards,not all models. That is the reason that sometimes pins are missing. You will see layouts for other items(options) missing also.  Ido not have A drawing or picture of your particular board  though.
Feb 05, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
Appearance on monitor is reddish in appearance
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Aug 10, 2008 | Hyundai L90D+ 19" LCD Monitor
Epson Stylus Pro 9600 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
