Question about Epson Stylus® C64 InkJet Printer
To reinstall Epxon C64 the driver doesn't install.
I bought all new inks, I cleaned the header , I tried aligning the printhead and all things to do in the toolbox. I downloaded an updated driver but it can't update if the original driver doesn't reinstall. I uninstalled again and reinstalled. the driver will not come in. When I reinstall I get the part of reinstall the options only.The driver does not reintall. I tried it from the disk and control panel. I've tried a week, different things. I have Xp .
It looks brand new inside. Not used that much.
I've asked for help/support and nothing yet
dorothy
  • 353 Answers
Hi dorothy - it seems you're having a few problems, but it's not clear from you post what the problem is. You can't "update" this driver, you must un-instalI before you re-install. I suspect you now have a very confused driver installation. The easiest way to get over this is to do a Windows XP system restore to a date before you first tried to update the driver. Once you have done this you may uninstall the original driver (use the Control Panel to do this) and install your updated driver. But don't do this unless you really need to. Why were you trying to update the driver in the first place?
If a system restore is not possible, try the following procedure. Click on start-control panel-printers and faxes. Do you have more than one copy of the printer installed? If so, we will uninstall all of them. But FIRST, make sure there are no jobs left in the print queue. Double-click each printer icon in turn and delete/cancel all print jobs listed. Then delete each "copy" of the printer (right click-delete the icon) except for the original one, which you uninstall using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps, or you want further information, please report back. If this advice has been of help, please rate it.
Posted on Feb 15, 2009
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Unable to align cartridges on Canon Pixma MP600 all-in-one printer. When trying to print many black streaks obscure printed area.
This sounds like a printhead problem.
The first thing I would try is to clean the printhead. Remove the cartridges and store them (stretch a piece of plastic electrical tape over the ink cartridge hole to keep the ink from drying out).
Remove the printhead and set it in warm distilled water and let the printhead sit overnight.
Remove the printhead from the water and blot the water with a clean lint free dry cloth (do not rub the printhead and contacts, or damage could occur. Set the printhead aside to air dry.
Once the printhead is dry, reinsert the printhead, remove the tape from the ink cartridges, reinsert the ink cartridges. Test print. This should clear the problem.
We can try a more aggressive cleaning solution of the distilled water doesn't clear the problem.
Let me know if you have any more questions. Thanks.
May 18, 2011 | Office Equipment & Supplies
We have put in all new ink cartridges but the black ink cartridge for documents still will not print. We have tried cleaning and deep cleaning twice to check the nozzels but that does not seem to solve the...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 11, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Sep 10, 2009 | Canon i9900 InkJet Photo Printer
Black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Jun 08, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Kodak ESP-5 AiO says "0%" ink even after I install new cartridges
Let's clean and align.
Make sure that there are 5 - 10 sheets of plain paper loaded in the paper tray.
2 Press menu to display the main menu.
3 Press down arrow until Maintenance is selected.
4 As needed, press down arrow until the desired option is selected.
5 Press OK.
6 Follow the prompts in the display screen to initiate or cancel the task.
These available maintenance options are shown below:
Check Ink Levels
Nozzle Check
Printhead Alignment
Clean Printhead
Print Demo Sheet
Print Test Page
From windows, : Open the Home Center Help panel by clicking Help on the Home Center window, as needed. Click Maintenance, and then click
Nozzle Check or Printhead Alignment.
Macintosh: Open the Home Center window and click Maintenance, and then click Nozzle Correction or Printhead Alignment.
Should be good now.
Regards
Richard.
Apr 24, 2009 | Kodak ESP 5 Printer
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon pixma mp780
Try uninstalling/reinstalling the drivers.
Is the error light flashing?
From the printer utility can you print a nozzle check sheet or align the printhead?
Does it seem to be printing (feeding sheet and moving printhead) or nothing happening at all?
Try removing all the tanks, take out the head. If blocked try cleaning manualy by running warm water over the ink ports/printhead jets - dry off and reinstall.
May 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus® C64 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
