Question about Canon PIXMA iP4200 InkJet Photo Printer
Test print on Canon Pixma ip4200 without computer
How can I print a test print without this printer being connected to a computer?
Benimur
  • 6966 Answers
SOURCE: ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Posted on Jul 30, 2007
SOURCE: Canon Pixma iP4200
Hey Cooldragon. Come back. It's still not working.
Posted on Dec 15, 2007
  • 286 Answers
When you plug your printer into the computer, what does the computer say?
Count how many flashes you are getting. Look in your owners manual to see what it says for that number of flashes.
Posted on Dec 30, 2007
  • 286 Answers
SOURCE: Pixma IP 4200 does not print
On the first question it sounds like the Mac might have a problem with its port. Check cable, try another device in that port. You really should ask around on a Mac site as this is not a printer problem since it works on another machine.
For the second person, you're using the machine plugged into a network? Is it plugged into router? If you're having an IP address conflict, you can get the problems you're describing. Make sure that you use a static IP address that is much higher address than any dynamic machines might be assigned.
For example, if you're using dynamic IPs, for example in the area of 192.168.1.100 and up. If you have four OTHER devices on your network, they may be 192.168.1.101, .102, .103, .104. So, the highest IP address they should be assigned is 192.168.1.104. Too allow for guest IP addresses, you should set your printer to be 192.168.1.109 so none of your devices or a guests device will ever be able to have a conflicting address.
  • 52 Answers
SOURCE: Canon Pixma IP90V self test
I went to the Canon web sit and found the procedure to run the self test. Go to Support and Down Loads, enter you printer type, and then type in selftest and it will show you how.
Posted on Mar 04, 2009
Pixma ip 4200
Change the black ink cartridge
Jun 28, 2012 | Canon PIXMA iP4200 InkJet Photo Printer
I am using canon 4200 printer. even deep cleaning did not solve my printing problem. what should i do. advise appreciated.
if its not printing just test the test page printing.If even u didnt get the test page check whether u get the correct drivers for ur printer. Then chek the toner for powder and check wheter the toner is defectd
Get the exact drivers here for ur printer: software.canon-europe.com
Jun 07, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have canon IP 1800 shows printer offline but every ting connected green light is on
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jul 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP4200
Nov 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Oct 20, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Just stopped printing
when i had this problem with my lexmark i had to uninstall all my printer software and reinstall everyhting from the disk for my printer. hope it helps.
Aug 02, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Ip4200 - printing issues!
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
37 people viewed this question
old marine
old marine
