Question about Whirlpool Refrigerators
Whirpool refrigerator et8chmxkto not cooling, fan was working unplugged and cleaned now fan will not run
I reset temper no change
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 8 Answers
SOURCE: subzero model 650 refrigerator
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Posted on Oct 13, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Posted on May 20, 2009
  • 864 Answers
SOURCE: Unplugged our refrigerator to move it. now it doesn't cool. Is there a reset button?
If you tipped it on its side you may have caused an air bubble to form in the refrigerant.
Plug it in, leave it empty, set for maximum cooling and do not open the door to check it for several hours.  Put a thermometer inside to check the actual temperature after three or four hours to see if it is getting cool.  Listen for the compressor to come on and whether there are any strange noises.  If you hear gurgling in the coils the refrigerant should be working OK.
Freezer temper 25 (selected -4) 2 deprost not working. 1 is working 1 is not working (inside fan area)
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Everest Refrigeration Refrigerators
Whirpool side by side refrigerator hot door gasket
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Apr 30, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The refrigerator is not cooling enough.
You will need remove the screws in the back of the freezer section, check to see if the little fan is turning, if not you will have to replace the fan motor, this is what circulates the air and keep the fresh food side cool.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Top freezes but bottum doesnt cool
The fan has quit working or is blocked. The fan is usually located in the back of the freezer, under a cover. this is easily changed if you have access to parts and a few tools, you can probably replace it yourself. Unplug frig while removing fan and the cover, remove the fan attaching screws, unplug the wire, reverse sequence for installation. It is safe to leave the frig plugged in while you get replacement fan. Whirpool makes Kenmore so you may be able to get the fan at Sears parts center.
Jun 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have an older Whirpool fridge it isn t cooling
does the motor run if not change the thermostat but if it runs the gas level are low in the system
Jun 16, 2009 | Refrigerators
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
