Question about BenQ DC3410 Digital Camera
My digi cam fell down ???
Hi , My BenQDC3410 slipped & fell down.it was a soft fall as i managed to break it, before it hit the floor hard. But when i picked it up , switched it on, the LCD display at the back had gone comletely white with a few spots & cracks visible internally.But the glass wasnt cracked or broken on the surface. Could some one tell me , what the problem is & Is this repairable or is the camera beyond repair now?? I stay in Bangalore -India. could you please suggest any authorised dealers here in bangalore or anyplace , where i can consult & get this problem sorted out? Nayeem- Regards.
    Genius:
  • 2,985 Answers
This is going to be new camera I am afraid. The repair options are limited because of lack of parts availability Look on your local internet for repair firms in your part of the world
Posted on Jun 11, 2007
SOURCE:
Which flooring is best for commercial space like gym or sports field. Is there any provider in Kansas city?
Having been in the flooring installation end of the business for over 20 years have you considered rubber mat flooring. It is about an inch thick and has interlocking tabs. Maybe I can find a hyper link.
Additionally on the market is a vinyl carpet tile...carpet on top....vinyl on the bottom...with a thin dense done inbetween
This is a very popular choice due to the ease of installation...using a peel and stick glue. It allows you to adhere the carpet tile to the floor and if future stains or issues arise you can take the carpet tile up and replace it. Very comfortable under foot....used on many commercial applications and now available at retail outlets like LOWES and home depot
Search the web for carpet tile...and releaseable adhesive for carpet tile.
You can compare prices vs wood, but I would not choose a wood floor personally.
Try
www.rubber flooring Inc
Oct 24, 2014 | Building Materials
MZ604 Motorola Xoom with no video
Sounds like you need the screen replaced: http://bit.ly/MotoLocation
Apr 12, 2014 | Motorola Xoom Tablets & eReaders
I fell and hit my shin hard it hurts realy bad what do i do
Well get fitted carpets next that wilkl break your next fall ,as for the shin ?' put a ice pack on it and dont walk on it for a day or so and make hubby do the housework
Dec 11, 2011 | Code Writer Wall Smilies
My sony digcam lens is stuck.. it just make some annoying sound but it doesn't close completely or open at all. it just say off and open ur cam.. how can i fix this? it fell 4 feet high.. but it...
Hi.
The drop has cause internal damage to the moving parts of the camera. The shock of the camera hitting the floor will have caused this.
The cost of the repair will differ depending on the damage caused by the drop.
You can get a quote directly from Sony by clicking on the link below or you can take the camera to a certified repair store.
https://eservice.sony.com/webrma/web/index.do
Regards.
Jun 02, 2011 | Cameras
I accidentally kicked my 1tb buffalo external hard disk and it fell the usb connection has been remove and when i connect it again the hard disk start to beep and the computer doesnt recognize and detect...
First try a different usb cable. The cable or the cable connectors may have been damaged as a result of the fall.
If that doesn't work and you are certain that your PC does not recognize the drive, then It appears to me that the fall damaged the delicate mechanical devices inside the drive and you will have to replace it.
Hard drives cannot withstand rough handling. If a hard drive is only dropped about 1 or 2 feet and it lands on a soft surface such as a carpet it MAY survive the fall. But if one falls from a higher elevation, (say 6 feet) onto a hard surfaced floor, it's almost a sure bet that the drive's internal mechanisms are permanently damaged.
To find out for sure, take it to a PC technician and have it tested. It should only cost you a few dollars.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Hi since last week (camera fell to the floor) the camera is not able to show the pictures on the display screen. The screen does however display pictures before it fell, so it seems the problem is in the...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 31, 2010 | Cameras
Power window fell down
HI, The window regulator on this model is a cable driven type and if the cable breaks or becomes unwound the window can fall down into the door. Sound like its time for a new regulator. If your handy its not a real hard task. Hope this helps
Aug 26, 2010 | 2004 Jeep Grand Cherokee
External hard drive fell on floor. Now will not
I would send it back to seagate but don't tell them it hit the floor
Jan 09, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
HP Pavilion xf125 PC Ntbk ac connection is broken won't charge
You need a new motherboard, ac connector are very hard to solder back on to motherboard and wouldnt advise anyone trying it.
Apr 11, 2009 | HP Pavilion xf125 (F3412HR) PC Notebook
BenQ DC3410 Digital Camera Logo
61 people viewed this question
Top BenQ Cameras Experts
Damen Wong
Damen Wong
Vincent_G
Vincent_G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
